Author Topic: Nasty noise !  (Read 686 times)
Offline tom38
  • Laser blue,leather,"19s,blue tints
Nasty noise !
« on: April 07, 2014, 07:00:09 pm »
Apart from needing a new rear offside wheel bearing, I was driving around local country roads tonight and noticed a nasty grinding kind of noise (only hear with window down) offside front wheel makes this noise when driving between 20-40 mph only when I turn left! Almost sounds like a stone stuck in the disc but only when I turn....
Anyone got advise please.... Much appreciated thanks tom.
Laser blue,leather,19s,blue tints
Offline Chris92
  • -Given: 33
Re: Nasty noise !
« Reply #1 on: April 07, 2014, 07:18:47 pm »
Could be a cv joint gone, any grease on the wishbone etc?
Offline tom38
Re: Nasty noise !
« Reply #2 on: April 07, 2014, 08:04:46 pm »
That sounds expensive.... Not looked closely,will tomorrow... Replaced cv boot on near side last year.... Grease everywhere lol
Offline Chris92
  • -Given: 33
Re: Nasty noise !
« Reply #3 on: April 07, 2014, 08:19:22 pm »
If it's knocking it could be already to late for the cv joint, in the past I've had ones knocking so I put a new boot on and packed it with grease and it was fine. I'd go with that way first and try that, that's if it even is the cv joint.
Offline tom38
Re: Nasty noise !
« Reply #4 on: April 07, 2014, 08:30:37 pm »
Ok than you for that, I'll get the suicide jack out tomoz n investigate further.
Offline biffobear
Re: Nasty noise !
« Reply #5 on: April 08, 2014, 06:49:09 pm »
Or could be wheel bearing
Offline MikLSP
Re: Nasty noise !
« Reply #6 on: April 08, 2014, 08:20:49 pm »
As a quick test without needing any tools, try putting your foot at the base of the wheel and sharply pulling the top towards you, if the bearing is knackered you'll noticed some movement and knocking.
Also try applying the brakes a little while you can hear the noise, when it is safe to do so, just to eliminate them as a source.
