Author Topic: Battery drain still happening... Completely stumped :( **UPDATE**  (Read 47764 times)
Offline Craigh1983
    • Leicester Wedding Photographers
Re: Battery drain still happening... Completely stumped :( **UPDATE**
« Reply #105 on: April 12, 2014, 12:18:09 am »
It's not that it doesn't let the Can bus sleep it just attempts to draw current to charge itself. The siren is a control unit in its own right and communicates via Lin bus single wire. If the master unit cannot see it then it continually sends a signal looking for it and also let's it draw current from the battery to charge itself, until the voltage stored reaches a set level. With a faulty cell this cannot be achieved, hence the drain - continuous draw.
Ok so this is all kinda starting to make sense to me now...
I'm going to sound a bit stupid again though and im just trying to make sense of it all... how come my stereo fuse is active and using a huge amount of power? is it because of the master control unit is constantly sending that signal?
Offline MJ
« Reply #106 on: April 12, 2014, 12:36:37 am »
That may be a separate issue entirely or it might be connected because one system is over ruling the other. The anti theft system has a high priority when it comes to power usage.
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
Offline Craigh1983
« Reply #107 on: April 13, 2014, 06:09:22 pm »
Having the new alarm fitted on Wednesday :)
Will be great if this sorts the issue. Everything is pointing to the siren but I'm tying not to get my hopes up.
Just did another check on the fuses and it's still draining. Same values as before so I hope they are still there when I take it to Ed on Wednesday!!
Offline SI-R32
  • -Receive: 125
Re:
« Reply #108 on: April 13, 2014, 06:13:59 pm »
Did you see if you have an amplifier under the seat for fuse 18?
Offline Craigh1983
Re:
« Reply #109 on: April 13, 2014, 06:17:03 pm »
Yep. There was an amp there. Never noticed it before!
Offline Craigh1983
« Reply #110 on: April 13, 2014, 06:18:57 pm »
Thanks for letting me know what that fuse was for Si :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #111 on: April 16, 2014, 05:31:29 pm »
Hopefully sorted Now
New Alarm Horn fitted - still battery drain - at least the car is protected now
New CECM fitted - No battery drain when checked
New Gateway fitted as there was a reoccurring fault, Comfort CAN in single wire mode. Gateway at fault
Cluster and Key coding
Location Great Yarmouth
Offline SI-R32
  • -Receive: 125
« Reply #112 on: April 16, 2014, 08:24:12 pm »
really glad this sounds like its finally over, hopefully Ed has sorted things a final time for you and you can finally enjoy your golf. fingers crossed mate
Offline Craigh1983
« Reply #113 on: April 16, 2014, 09:16:53 pm »
Honestly mate me too! This car has stressed me out way too much! The problem
Has been going on for over a month now with all the electronics failing first of all.
Ed was an absolute star today. Spent all day on my car and had the dash out soldering wires n all sorts. Sorted it in the end so massive thanks to you mate for that!! :happy2:
Also John (Doylebros) on the forum has been a massive help. Helping me out over the phone and sending me all the parts... Twice! Also everyone else on the forum thank you for your help! John_A and Matto for doing scans for me! What a great bunch of people!
Ed kindly pointed out that I have the start of some rust on the wheel arches lol I look forward to now trying to get that sorted hahaha
Offline brummo
  • Newbie
« Reply #114 on: September 15, 2022, 07:53:27 pm »
Hi all, i appreciate that this topic is old but i'm trying to diagnose battery drain.  I've done loads of reading up and just wondered if there is a consensus on what is the key issue, i.e. is it the alarm horn siren (which doesn't work on mine, or the door lock mechanism, again not working on mine on the passenger side.  Tried a replacement CCM no joy, next step is possibly the CECM.  Does coding the alarm out help?
Currently drawing 98ma
Here are the relevant parts of my scan
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 T
Component: 0W KSG 0560
Coding: 81E802087F2D8505485BC61000
Shop #: WSC 00000 785 00200
VCID: 4189F0031889C38E4D-8014
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
3 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Component: Tuersteuergeraet 09 0116
Coding: 0000052
Shop #: WSC 01279 785 00200
VCID: 3169A0C3A829530EBD-8064
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
012 - Electrical Fault in Circuit
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Offline Grevling89
« Reply #115 on: November 05, 2022, 08:28:13 pm »
3 Faults Found:
Coding: 0000052
2 Faults Found:
Did you try the reverse engineering method of singling out what circuit that's causing the drain?
This video helped me loads when troubleshooting a parasitic battery drain:
. Gentle warning about an immensely American aesthetic and way of speaking, but the info is good.
2007 MK V - Pearl Black - 5 door - Happily stock
