Author Topic: think my pcv has gone!  (Read 11160 times)
Offline BMX
Re: think my pcv has gone!
« Reply #15 on: October 12, 2009, 07:03:52 pm »
something to do with the crankcase check valve maybe? to be honest i did run it open for a day until i realised, but after that everything was ok. it was a week after and when i removed it the problem started??
"If Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
« Reply #16 on: October 12, 2009, 07:34:14 pm »
i ran it for a week, why would leaving the drain off open cause my problem?
It shouldn't as you would effectively just be running a "vent to atmosphere" set up but will a slight loss of boost.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #17 on: October 12, 2009, 07:46:49 pm »
I would suggest somethings gone wrong with your install, then when you tried to revert to normal its persisted.
oil out of the cap is a symptom not the cause. somethings the wrong way round pressurising your crankcase.
Im sure the dealer will sort it out. no worries
of note be careful you dont run out of oil in the meantime!
Red ED35 5dr DSG
BLOG | BUILD
Offline BMX
« Reply #18 on: October 12, 2009, 08:11:24 pm »
ok cheers for the advice, the oil is ok just checked.
« Reply #19 on: October 12, 2009, 08:19:20 pm »
I drove all the way to Germany with the tap open and ran fine with no loss of Boost whatsoever!  :innocent:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #20 on: October 12, 2009, 08:20:58 pm »
thats cos its never 'in boost'  :surprised:
Red ED35 5dr DSG
BLOG | BUILD
« Reply #21 on: October 12, 2009, 08:21:48 pm »
 :confused:
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« Reply #22 on: October 12, 2009, 08:55:49 pm »
hmm, i would suggest posting on vwvortex in the tfsi section, over there in america they are all running the catch can and im sure one of them will know for sure whats up!
http://forums.vwvortex.com/zeroforum?id=739
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
« Reply #23 on: October 13, 2009, 01:30:48 pm »
Any news as yet?
P.S. Air Filter was posted last Friday so you should get it any day!  :happy2:
Offline BMX
« Reply #24 on: October 13, 2009, 02:00:42 pm »
no call from vw yet.... got the airfilter on saturday thanks alot for that mate  :drinking:
Offline edition_30
« Reply #25 on: October 14, 2009, 08:57:42 am »
any update on this mate?
« Reply #26 on: October 14, 2009, 09:25:41 am »
that car was in boost all the way there and all the way back! ;)
Offline tony_danza
  • -Receive: 112
« Reply #27 on: October 14, 2009, 09:55:02 am »
Sounds like the valve is the wrong way around/stuck?? I'd have expected it to p*** oil down the inlet, rather than back up and blow out of the cap.
Crawl there ASAP.
Sideways yo!
Offline BMX
« Reply #28 on: October 14, 2009, 05:35:02 pm »
ok just thinking here, if i blew down the pipe from the inlet manifold to the rocker cover should there be some resistance or not because i did and there was no resistance it was as free as a bird
« Reply #29 on: October 14, 2009, 06:46:38 pm »
So what have VW said? If this as you say is an issue with the PCV fix we all have I for one would like to know. If not we need to clear this matter up.  :happy2:
