Author Topic: High idle  (Read 5273 times)
  • -Receive: 291
High idle
« on: April 11, 2014, 12:13:47 pm »
Noticed this earlier in the week. Set off from home, reached a junction and waited. Whilst waiting I noticed the idle speed was around 1250rpm. Normally it's around 800rpm within a few seconds of ignition. This is now a persistent issue. Not noticed any change in power but the car feels rougher when turning off the ignition - it almost feels like I've stalled the car.
Will run VCDS this weekend and gonna go see Alex next week but would be good to prepared.
Any thoughts?
Offline MJ
Re: High idle
« Reply #1 on: April 11, 2014, 06:31:33 pm »
PCV valve on the front of the cam cover can cause this.
« Last Edit: April 11, 2014, 06:37:35 pm by MJ »
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
Offline biffobear
Re: High idle
« Reply #2 on: April 11, 2014, 06:34:19 pm »
PVC valve on the front of the cam cover can cause this.
yes, had this and fitted pcv, ok now
Offline MJ
Re: High idle
« Reply #3 on: April 11, 2014, 06:38:34 pm »
I would just like to clarify that there is no such thing as a PVC valve, stupid autocorrect.
Offline biffobear
Re: High idle
« Reply #4 on: April 11, 2014, 06:42:57 pm »
I would just like to say dyslexia is nothing to be ashamed about :signLOL:
Offline MJ
Re: High idle
« Reply #5 on: April 11, 2014, 06:46:56 pm »
It's alarming that my phone has PVC in its memory bank  :confused:
Offline betty_swollox
  • -Receive: 29
Re: High idle
« Reply #6 on: April 11, 2014, 06:48:44 pm »
hahahaha
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline Alex.Parris
Re: High idle
« Reply #7 on: April 11, 2014, 08:23:18 pm »
hah!
I had the same issue and was the pcv valve
Leon Cupra REVO Stage 2 | Full Milltek Exhaust | AMD Induction Kit | Forge DV | Eibach Sportlines
  • -Receive: 291
Re: High idle
« Reply #8 on: April 12, 2014, 05:49:21 pm »
Ran vcds and got the following:
001287 - Idle Control System RPM
P0507-001-Higher than Expected.
Offline GunnerGibson
Re: High idle
« Reply #9 on: April 13, 2014, 06:13:52 pm »
Pcv replacement sorted this out on my cupra... if after replacing the pcv the issue remains check charcoal cannister.
  • -Receive: 291
Re: High idle
« Reply #10 on: April 15, 2014, 06:56:33 pm »
Yup replacing the PCV solved the problem. After replacing, on first ignition, it seemed to hesitate but was fine on second and subsequent attempts.
Re: High idle
« Reply #11 on: May 14, 2014, 11:21:17 pm »
good stuff... problem was haunting me for ages.. annoying to be honest. Mine occurred when I installed an Intake... bizarrely
