Author Topic: Mk5 boot pop mod will not work?!? Any one else had this?  (Read 1279 times)
Offline MJ
« on: April 11, 2014, 06:19:39 pm »
Fitted the parts for the boot pop mod and coded in with VCDS and it worked fine for a couple of days but now seems to have lost its mojo?
They were all genuine parts fitted and I even tried a set of new poppers to no avail. I've adjusted the tailgate, lubricated the seals and latch but it refuses to work if I don't use it for a day or two.
Anybody come across this or had any issues of their own that can point me in the right direction? It's a sh*t hot-mod and such a shame it doesn't want to work.
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
Offline biffobear
Re: Mk5 boot pop mod will not work?!? Any one else had this?
« Reply #1 on: April 11, 2014, 06:40:18 pm »
They are bad for that, some days the boot flys open, some days it just pops and stays down
Offline MJ
« Reply #2 on: April 11, 2014, 06:45:38 pm »
Yeah it just seems a bit hit and miss. It's really annoying though as I'm modding the car to death but keep getting held back with piffy little crappy issues. I do all the work myself so I know it's been done right but when something fails or stops working it causes me some confusion.
Offline skard
  • -Receive: 245
« Reply #3 on: April 11, 2014, 06:51:26 pm »
Try exercising the strut up and down a few times then try to see if it flies open.
Also remember this is a mod that wasn't an option so we have to tolerate it being the way it is really.
Offline N8KOW
  • Detailer - 2014
    • Kowalski Details
« Reply #4 on: April 11, 2014, 07:15:44 pm »
Same thing happened with mine! I will test again soon!
2014 Mk7 Golf R on Order...
Offline prp74
  • -Receive: 126
« Reply #5 on: April 11, 2014, 07:37:26 pm »
The same happens to me as well, especially in the cold. But as mentioned exercise the strut up and down, that should help.
Offline sootpig
« Reply #6 on: April 11, 2014, 09:00:15 pm »
Same here  loads of grease on strut pins and make sure you pop it before going public at tescos  :signLOL:
Warm weather helps but That's not going to happen too often
Offline N8KOW
  • Detailer - 2014
    • Kowalski Details
« Reply #7 on: April 12, 2014, 02:03:21 am »
 :congrats:
Offline SI-R32
  • -Receive: 125
« Reply #8 on: April 12, 2014, 07:30:20 am »
you might as well get used to it mate, cold day no chance, hot day works perfect. at least on a cold day you can still get your fingers just under the cracked edge and lift it up really easy.
also i've just discovered from a mk4 boot pop mod you can get a beetle latch that has a spring on it for about 12 quid, going to add this to my car to try it out.
http://i65.photobucket.com/albums/h208/old_n07/misc%20golf%20pics/boot/DSC01734.jpg
