Author Topic: Ttrs lpfp problems?  (Read 12343 times)
Offline Pikey Motorsports
Ttrs lpfp problems?
« on: April 11, 2014, 10:21:00 pm »
Anyone getting any problems with there's? I have been having probs with my car cutting out under full power in 5th and 6th and belive it maybe the cause of the pump
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline vRSAlex
  • -Receive: 253
Re: Ttrs lpfp problems?
« Reply #1 on: April 11, 2014, 11:10:04 pm »
Yes it can happen.  It can cause the controller to overheat then shut down, causing the cuts.  With a map more suited to your build, and getting rid of the sh*t RS4 injectors then you should be fine.
Follow AKS tuning on Facebook
« Reply #2 on: April 11, 2014, 11:17:07 pm »
I've not had an issue like yours but on two occasions so far (over a 4 month period) I've noted this fault code. I had no CEL and the car has always performed well.
012555 - Low Pressure Fuel regulation
               P310B - 008 - Fuel Pressure Outside Specification - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 47878 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:56:04
             Freeze Frame:
                    RPM: 765 /min
                    Load: 18.0 %
                    Speed: 0.0 km/h
                    Temperature: 91.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.843 V
The second occasion happened even after I changed the low fuel pressure sensor.
Have you scanned for a fault code and done  a basic setting for the pump?
« Reply #3 on: April 11, 2014, 11:19:15 pm »
Been wondering what it is and something suddenly just popped up whats pointed me to the problem!
Was something what needed sorting but didn't bother to much at only high speed so wasn't on the top of the to sort list...
See apr have removed it from there kit!
Will a ttrs controller fix it also?
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
« Reply #4 on: April 11, 2014, 11:20:35 pm »
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 47878 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:56:04
             Freeze Frame:
                    RPM: 765 /min
                    Load: 18.0 %
                    Speed: 0.0 km/h
                    Temperature: 91.0°C
                    Temperature: 43.0°C
                    Voltage: 13.843 V
I belive that's normal... Only some are having probs with the car cutting out at high soeed
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: April 11, 2014, 11:22:55 pm »
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 47878 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:56:04
             Freeze Frame:
                    RPM: 765 /min
                    Load: 18.0 %
                    Speed: 0.0 km/h
                    Temperature: 91.0°C
                    Temperature: 43.0°C
                    Voltage: 13.843 V
That code is normal.  Map spec is different to what the pump delivers.  Just need the specs broadening in the map.
« Reply #6 on: April 11, 2014, 11:23:41 pm »
Touch wood. I've had no dramas, yet.  :scared:
« Reply #7 on: April 11, 2014, 11:23:55 pm »
Seem to recall that with the ttrs controller you lose the pump priming function when you open the drivers door.
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: April 11, 2014, 11:24:20 pm »
Ttrs controller causes more issues.
« Reply #9 on: April 11, 2014, 11:28:26 pm »
Hmm so what injectors do you recommend then? Revo only do rs4 I belive? Is there no controller what helps alex
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
« Reply #10 on: April 11, 2014, 11:29:43 pm »
Thanks for that Alex.
It may be coincidence but I also noticed on each occasion prior to scanning the car my polar readout showed 0 bar for both lpfp and fuel rail pressure.
« Reply #11 on: April 11, 2014, 11:48:10 pm »
I had probs from day1 mate so you maybe ok..
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
« Reply #12 on: April 11, 2014, 11:51:40 pm »
You prob drive harder than me  :laugh:
I've done a couple of trackdays though so should be ok
« Reply #13 on: April 11, 2014, 11:55:59 pm »
It only does it when driven hard mate sometimes in 5th sometimes 6th doesnt always do it and wirks faultlessy other then that
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline vRSAlex
  • -Receive: 253
« Reply #14 on: April 12, 2014, 12:10:57 am »
S3 injectors flow more and spray better than RS4 injectors.  Always have done.  Ditch the Revo map and go to Niki.  The big turbo maps were designed around ATP cast manifolds and GT series turbos.  Done about 5 years ago and things have moved on loads since then.  There is just no need for them to revisit them at the moment. I'm sure they will once they start doing their own bt kits.
Rs4 injectors were and are only used on US based maps as they were all that was available until the TTS was launched there.
I've just ordered some 155 bar return valves for the two Nortech kits I'm doing, and for my build. This should give enough fueling hopefully before needing anything else.  So many cool things that Niki will be working into these new maps.
