Author Topic: which diverter valve  (Read 2420 times)
Offline denzilbud
« on: April 12, 2014, 12:34:16 pm »
Hi all I know its been done a thousand times already but which diverter valve do I need for my o7 plate golf gti the engine code is bwa I think new to vws so I havent got a clue.manythanks in advance
Offline Human Joist
Re: which diverter valve
« Reply #1 on: April 12, 2014, 12:53:45 pm »
Go to VW and order the newest version for your car.
Offline denzilbud
« Reply #2 on: April 12, 2014, 01:10:04 pm »
Im ordering it through my work as I get good discount from vw but on our systems theres more than one listed so just need to find out which one but thanks for your input
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: April 12, 2014, 01:13:33 pm »
Offline denzilbud
« Reply #4 on: April 12, 2014, 06:53:33 pm »
Thankyou much appreciated
« Reply #5 on: April 12, 2014, 06:55:42 pm »
P.
Offline denzilbud
« Reply #6 on: April 19, 2014, 02:27:27 pm »
 Hi all Replaced my c diverter valve for a g and car still seems sluggish where else can I check . many thanks
Offline Nico2904
« Reply #7 on: April 19, 2014, 02:55:17 pm »
PCV, coilpack, sparkplugs
Offline denzilbud
« Reply #8 on: April 19, 2014, 03:16:09 pm »
Just had the ignition coils replaced is there a way of checking the coil pack.its not long had the sparkplugs changed and major service will have a look into the pcv.many thanks
Offline denzilbud
« Reply #9 on: April 21, 2014, 01:37:16 pm »
Also getting a fuel smell on cold start up and car seems to be more jerky now am I right in thinking to test pcv you remove dip stick and if idles affected its ok
Offline usmangti
« Reply #10 on: April 21, 2014, 02:21:00 pm »
Offline parkysan
« Reply #11 on: May 02, 2014, 12:55:13 pm »
I've just bought a G diverter valve from Awesome GTi http://www.awesomegti.com/parts/engine/valves/oem-2-0t-diaphragm-diverter-valve-06f-145-710g# My car's in the garage next week to have both outer CVs replaced so thought I'd do it at the same time. I really struggle to get near 30 mpg, even with a light foot so I'm hoping I'll see an improvement here. It's also done 97k so it's probably a good time to change it anyway! I've tested the PCV and this seems fine i.e. lumpy idle when remove dipstick.
I'll let you know what difference it makes.
Offline parkysan
« Reply #12 on: May 07, 2014, 07:05:59 pm »
Turns out the car already had a GFB DV+ fitted, but after reading this post I asked them to swap it out anyway so that I could compare and I could easily drop the GFB back in if I needed to.
Anyway, even though it's only been a day here are my initial thoughts.
I took it on a 'sensible run' with the kids through A & B roads and clocked up 38 mpg average, way more than <30 I was getting on a long-distance cruise! This is a huge difference  :happy2:
I know that better fuel economy isn't everyone's idea of an improvement, and let's be honest I wouldn't have a GTi if I was that bothered about it, but when you do quite a few miles it's nice to know you can get reasonable mpg when you want to. The car also seems to start slightly quicker, has smoother idle and even appears slightly quieter although this could all just be my perception.
The throttle response does seems a little slower, but not by much and when I floor it it seems to pull just as well up through the revs.
Also, no fuel smell on cold start anymore so maybe the GFB DV+ was faulty anyway?
I know it's early days but all in all, I prefer the way the car drives with the Rev G fitted but will give it a few weeks of driving before I give my final verdict.
Hope this helps some of the guys who are undecided which DV to fit.
