Author Topic: New pads needed for NQSBBK - ideas?  (Read 1122 times)
Offline AndyED30
  • ED30
« on: April 12, 2014, 07:30:11 pm »
Can anyone advise from experience of a good pad to replace the Textar ones I've been running on my NQSBBK?
The Textar pads have done really well and I'd get them again............unless anyone can recommend a no-brainer replacement.
Brembo / Pagid / Ferodo etc?
I don't do track days and just want something that doesn't squeak and it as reliable as a German quality control checker...............
Cheers!
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
Re: New pads needed for NQSBBK - ideas?
« Reply #1 on: April 12, 2014, 08:50:44 pm »
Same again pal.... You running the porsche shims on the pads
Offline arris
« Reply #2 on: April 12, 2014, 09:13:50 pm »
Can I just asked in here what discs people would recommend?
Is there any good drilled/grooved ones?
Offline AndyED30
  • ED30
« Reply #3 on: April 13, 2014, 10:28:39 am »
Thanks Dave, I do have some shims to add to the next ones yes. Squeaking does occasionally get a bit annoying!
Cheers for the good advise as always!
Offline AndyED30
  • ED30
« Reply #4 on: April 13, 2014, 10:30:30 am »
Arris.
I've got drilled Mercedes disks from DaveB so maybe ask him if he can hold of these as they match very well with the set-up.
Andy.
Offline Russ_leeds
« Reply #5 on: April 13, 2014, 11:45:22 pm »
I run the pagid rs4-2 blues in mine. Great setup IMO  :drinking:
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline arris
« Reply #6 on: April 14, 2014, 08:12:21 pm »
Can anyone confirm if these are the correct pads for my calipers which are 986.351.412 & 422
http://www.ebay.co.uk/itm/300930782312?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
And the ones referred to in this thread?
Offline will88
« Reply #7 on: April 14, 2014, 10:53:26 pm »
Appears to be so as there not the boxster-s. How come your not thinking of running boxster-s pads to gain the extra width in the upswept area and cut the pads slightly down to fit..?
Offline arris
« Reply #8 on: April 15, 2014, 07:31:18 pm »
I didn't know that was a option?
Any more details if it's worth doing or a guide to do it?
Offline will88
« Reply #9 on: April 16, 2014, 09:20:15 am »
I would template the Boxster pads onto the Boxster-S get the grinder out and go from there. Start slowly a little bit at a time until they seat in and fit. Perhaps purchasing a set of cheaper pads like Textar compared to DS2000 would be a safer option if things go bad.
I've only done the shims for the Boxster-S currently as I managed to get hold of some race titanium shims for the price of normal shims, and when I brought the calipers their were still loads of material on the brake pads. Once these discs or pads wear out I will be using the Boxster-S pads as I don't like the unsightly look of the 10mm unswept area.
