Author Topic: rns510 battery drain  (Read 3769 times)
Offline red-snake
  • RED-SNAKE
« on: October 13, 2009, 01:49:20 pm »
since fitting the rns510 my battery keeps going dead and im getting sick of getting the jump leads out.
iv read that it has a small amout of drain coming out of , how would i stop this
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
Re: rns510 battery drain
« Reply #1 on: October 13, 2009, 02:11:06 pm »
Have you updated to the 2660 firmware?
If so, downgrade to the 1100 firmware. Fixed my issues with the battery draining.
If not, you will need a newer CAN Gateway and it recoding.
#1493
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #2 on: October 18, 2009, 03:10:01 pm »
Just as a note the minimum revision CAN-Gateway that works is K
So you need to make sure when upgrading you have a K or Newer revision
Carl :happy2:
Offline red-snake
  • RED-SNAKE
« Reply #3 on: October 18, 2009, 07:21:55 pm »
iv taken it out till i sort the problem out so back to my rcd300 for now .. :confused:
Offline red-snake
  • RED-SNAKE
« Reply #4 on: October 20, 2009, 01:40:03 pm »
all fixed now
the battery was draing as i had a live feed coming from my glovebox light and was draing my battery.
Offline flyboy1976
« Reply #5 on: October 30, 2009, 04:28:59 pm »
Latest revision CANBUS Gateway for golf mk5 is 1K0 907 530 ''S'' .This apparently cures the battery drain issue upon either installing a version C rns 510 or doing the f/w 2660 update to earlier revisions.
So if you are considering the firmware update or buying a version C then my advice would be to avoid this happening check the gateway or to be safe get the gateway changed and  firmware updated at the stealers, then if it goes tits up its not your problem.
« Last Edit: October 30, 2009, 06:22:12 pm by flyboy1976 »
