Author Topic: Revision G DV Question  (Read 1850 times)
Offline Juicetin
« on: April 16, 2014, 05:00:33 pm »
Is the Rev G diverter valve sturdier than the original Rev C on early Mk5 Gtis, ie. is the diaphragm bit itself beefier?  should it last longer than the Rev C ?
dansmith180
Re: Revision G DV Question
« Reply #1 on: April 16, 2014, 05:29:55 pm »
The revision G is the newest and strongest diaphragm type valve (like the revision C) but if you want it to last then get the revision D which is a piston type valve and should pretty much last forever.
Hope this helps.
Offline robern2
« Reply #2 on: April 16, 2014, 06:16:03 pm »
Rev h is the newest - a different type to the g. G's are available and cheaper.
Offline dave_b
« Reply #3 on: April 16, 2014, 06:23:10 pm »
i thought the rev g, was the one to have. i just replaced my rev d with one....didn't know what one i had in so just replaced it any way
dansmith180
« Reply #4 on: April 16, 2014, 06:34:14 pm »
I didn't know there was a H now? I was at VW getting mine about 5 weeks ago and D or G were the only options.
Offline ILoveTuna
« Reply #5 on: April 16, 2014, 07:30:35 pm »
I had a g fitted a few weeks ago. Happy with it not heard of any failures with them to date.
Offline akbarirfan
  • -Given: 81
« Reply #6 on: April 16, 2014, 07:34:38 pm »
H exists, I believe it is more expensive but not sure what the benefits are...might be piston driven like the rev D.
There are many threads on this topic buddy
Offline robern2
« Reply #7 on: April 16, 2014, 07:56:15 pm »
H is an allegedly improved piston type
Saintsteve
« Reply #8 on: April 16, 2014, 08:05:11 pm »
Question is, is it suited to run with the AXX, BYD , CDL, or the BWA variant.
stick with a G  :wink:
« Last Edit: April 16, 2014, 08:50:59 pm by Saintsteve »
Offline Juicetin
« Reply #9 on: April 16, 2014, 08:48:06 pm »
I presume people are running G's with remaps without any problems ?
Saintsteve
« Reply #10 on: April 16, 2014, 08:51:49 pm »
No issues, but I would inspect it at least once year as part of your service regime .
Offline ILoveTuna
« Reply #11 on: April 16, 2014, 08:52:03 pm »
Yes.  :smiley:
