Author Topic: Intermittent power loss help needed  (Read 1953 times)
Offline Andy69
« on: April 18, 2014, 12:10:38 am »
Right, my remapped mk5 gti has started playing up.  70% of the time it just loses power, it drives and runs fine (no missfires or juddering etc) it just feels like it's only making 100hp. It Doesn't put the eml on either.
Iv had vag com on it and it chucked up a code about the maf, so I unplugged the maf and it started running well again (almost felt like full power) but it put the eml on. So we assumed the maf was dead, got a new 1 from dealer car ran great for 2 miles then went to no power again.  Unplugged maf and it ran well again.  Check the code and it came back p0172 "system to rich bank 1".
I fitted a rev G DV two weeks ago before maf because that was on its way out and stripped and cleaned the PCV, so I'm stumped tbh.
Could it be a a naff part from the dealer?
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: Intermittent power loss help needed
« Reply #1 on: April 18, 2014, 09:00:24 am »
What was the code you pulled when you had it scanned?
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline SurreyED30
« Reply #2 on: April 18, 2014, 10:39:48 am »
If it's running to rich perhaps the fuelling on your map set up is set to "rich" so will need adjusting? Mines quite rich so played around with settings through the laptop and my REVO SPS switch now it's sweet  :happy2:
« Reply #3 on: April 18, 2014, 11:06:44 am »
Offline Andy69
« Reply #4 on: April 18, 2014, 08:41:50 pm »
P0172 system to rich bank 1
Iv done some data logging and the afr's are spot on on idle and wot, with the maf plugged in and unplugged so I'm baffled
Offline Andy69
« Reply #5 on: May 06, 2014, 10:30:41 am »
Fitted the original airbox and car runs great now so obv dint like the intake kit
Offline edd666999
  • -Receive: 89
« Reply #6 on: May 06, 2014, 10:59:54 am »
Which map and which intake did you have?
Offline Andy69
« Reply #7 on: May 24, 2014, 11:55:54 pm »
Amd remap, I made the intake myself out of some left over 80mm pipework and a pipercross filter from my last project.
