Author Topic: Annoying window issue..  (Read 1680 times)
Offline mrzed
« on: April 18, 2014, 08:00:26 am »
Not had the car long but this is starting to bug me....
If the window is open about 2 inches and i try to close it, the window will only open all the way, then it will let me close it, once it's fully opened.
It only does this when it's open a small amount.
Am i missing a simple trick here?
Chris
Offline Little_Dave
Re: Annoying window issue..
« Reply #1 on: April 18, 2014, 08:21:37 am »
There's a way of resetting the memory of the window, if you open the window fully and hold the button down then fully close it, again holding the button, it should cure the problem
I was told it was something to do with the window motor remembering how you use it so should be better after a reset
Dave
Offline mb
  • -Receive: 29
« Reply #2 on: April 18, 2014, 02:34:31 pm »
Dave
Had the same problem a while ago and the above procedure would cure it for a while but the fault would eventually return.  I ended up changing the door controller and its been fine since.
Offline sam25man
« Reply #3 on: May 16, 2014, 12:12:05 am »
Dave
Will need to try this, its a small thing but so annoying!
downsideup
« Reply #4 on: May 20, 2014, 04:10:30 pm »
Dave
i have the same problem on my Touran and am going to try this, found this helpful video to help:
Offline Lewis
« Reply #5 on: May 20, 2014, 10:00:58 pm »
My driver side window does this from time to time too! It is so annoying. It doesn't seem to do it if the window is wet though, so I think in going to try some lubrication in the b pillar groove where the window slides up and see if that helps the situation...
