Author Topic: Help with intake manifold flap code P2008-001 - how to sort  (Read 5997 times)
Offline rallycross
« on: April 20, 2014, 11:41:58 am »
I've done a search and still not clear on what we can do about this fault can anyone help us out, located West London/Surrey
Car = 2005 Gti DSG, when re-set the engine light will come back on after a few days driving (car drives fine although does not start as well as it should when cold).
Fault code is P2008-001 intake manifold flap bank one electircal malfunction
The pic below shows the scan result
https://twitter.com/Rallycrosscraig/status/457828979651932161/photo/1
The garage I am using is an indy specialist and does not know much about this fault, he recons its 4 or 5 hours work to do.
So, is this scan detailed enough or will VAGcom tell us more?
How much is a new inlet manifold?
Can the existing one be fixed (eg remove flaps?)
Anyone got a spare inlet mani to suit?
thanks for any help.
Offline bigmig95
  • -Receive: 50
Re: Help with intake manifold flap code P2008-001 - how to sort
« Reply #1 on: April 20, 2014, 01:20:39 pm »
Quite likely to be the manifold flap motor.  Got the same issue on mine, it's around £180 for a new motor. You won't need a new manifold.  Worth doing the motor adaption process with VCDS just to see if it clears first.
willni
« Reply #2 on: September 24, 2018, 06:47:12 pm »
Anyone else got any advice on this? I got the same code and wondering on best method to sort it.
008200 - Intake Manifold Flap; Bank 1
               P2008 - 001 - Electrical Malfunction
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 41109 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:09:46
             Freeze Frame:
                    RPM: 3337 /min
                    Load: 8.2 %
                    Speed: 63.0 km/h
                    Temperature: 82.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.351 V
012600 - Intake Manifold Runner Control
               P3138 - 008 - Regulation Deviation
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 41109 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:09:46
             Freeze Frame:
                    RPM: 3337 /min
                    Load: 8.2 %
                    Speed: 63.0 km/h
                    Temperature: 82.0°C
                    Temperature: 20.0°C
                    Voltage: 14.224 V
Readiness: N/A
willni
« Reply #3 on: September 24, 2018, 07:18:59 pm »
Got sorted, performed the Basic setting.
Prerequisites:
Ignition ON
Engine OFF
System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 142
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch Ignition OFF for at least 60 seconds.
Notes:
Timing chain driven engines such as the CCTA, CBFA and CCTA were phased in during model year 2008. Those engines use an entirely different IMRC system which uses engine vacuum in conjunction with a solenoid so Basic Settings 142 must be completed at idle.
Never run Basic Settings with the IMRC motor linkage disconnected from the intake manifold. It may damage the new part.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #4 on: September 24, 2018, 08:01:54 pm »
Guess I may as well join the bandwagon, it seems a common fault. Willni I’ve done that reset before and the problem just returns
 Faults Found:
012599 - Intake Manifold Runner Control
               P3137 - 001 - Basic Setting not Completed - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 170954 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 63.0°C
                    Temperature: 48.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
001602 - Sensor Reference Voltage A: Circuit
               P0642 - 002 - Low - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 170954 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 63.0°C
                    Temperature: 48.0°C
                    Voltage: 11.938 V
Black Ed30
willni
« Reply #5 on: September 24, 2018, 08:12:54 pm »
Does the fault return quickly or is it a mid-term fix? Don't particularly feel like forking out for a new one at £180.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #6 on: September 24, 2018, 09:35:36 pm »
Hi Willni I would say it’s a mid term fix, I did the reset mid July and scanned it to weeks ago no faults picked up. The engine light came on last week.
There is an old thread on here somewhere with the same problem, although I think there are several part numbers for a similar part
Black Ed30
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #7 on: September 25, 2018, 10:53:23 am »
What Plugs are you guys running ?
Silver is the way !
willni
« Reply #8 on: September 25, 2018, 07:16:34 pm »
OEM from TPS
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #9 on: September 25, 2018, 10:55:25 pm »
currently ngk iridium spark plugs, previously had OEM plugs and had the same issue
Black Ed30
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #10 on: September 26, 2018, 10:34:10 am »
OEM from TPS
A popular plug used to be the "Nology" Plugs, they brought a fault code up pretty much the same.
Silver is the way !
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #11 on: September 26, 2018, 01:14:19 pm »
BKR7EIX are what you want. Don't buy from an unknown eBay seller - lots of fakes around
