Author Topic: MK6 Drivers window ...  (Read 489 times)
Offline ARV_90
« on: April 21, 2014, 05:26:13 pm »
Just noticed that the window one touch up has stopped working, The passenger side one is fine.... Had a look in the convenience menu but cant see anything in there that you can alter... Anyone else had this ?
Re: MK6 Drivers window ...
« Reply #1 on: April 21, 2014, 05:35:46 pm »
You tried fully lowering the window then close it keeping the up button depress for 10 seconds after full window closure?
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #2 on: April 21, 2014, 05:36:07 pm »
press and hold the down button for 10 seconds then the up button for an 10 seconds
then tap down once and see if its working again
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline ARV_90
« Reply #3 on: April 21, 2014, 05:44:32 pm »
mmm just tried doing the hold for 5 seconds and it still the same... One touch down works fine just the up... could it be the anti pinch sensing kicking in  :confused: go and try it for 10 seconds
Offline ARV_90
« Reply #4 on: April 21, 2014, 05:53:59 pm »
Nope still the same... even lubed the window guides with silicone but all seems fine. Its no good i'm going to have to give in and read the handbook LOL
Offline ARV_90
« Reply #5 on: April 22, 2014, 08:34:52 pm »
Well.... Even reading the manual hasn't sorted it, Basically it says to do what I have been trying already... Any other suggestions guys  :sad1:
« Reply #6 on: April 22, 2014, 10:19:06 pm »
I suppose you could do the drastic thing of disconnecting the battery for a short while then try repeating the adaptation procedure. Personally I would just keep the button pressed till the window goes fully up.
Offline doylebros
« Reply #7 on: April 23, 2014, 09:33:32 pm »
This is worth a read on that problem:-
http://wiki.ross-tech.com/wiki/index.php/00932
