Author Topic: hatch not opening (Now fixed)  (Read 5020 times)
Offline sootpig
« on: April 21, 2014, 07:25:28 pm »
00950 - Central Locking Motor - tailgate (V53); UNLOCK
            007 - Short to Ground
 Above scan details are the only  fault code showing.  No visible signs of wear to wires in rubber sleeves
  Opening hatch only possible via inner release trigger
  Even reset pop mod in desperation :signLOL:
 Any help or a point in the right direction  Thanks
« Last Edit: May 03, 2014, 03:41:12 pm by sootpig »
Offline timwills17
Re: hatch not opening
« Reply #1 on: April 21, 2014, 07:56:09 pm »
It's gonna be an annoying one it's definitely ya wiring problem...best thing is check that boot plug is getting 12v when you press boot release button on your key. If it is and it isn't rep sounding, could be tailgate handle popper itself.
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #2 on: April 22, 2014, 01:23:41 pm »
if u desperately need to get in to it
put the back seats down and in the middle of the boot trim there is a small plastic toe eye cover looking thing
pull it off and stick your finger in to the hole near the back there is a little lever that you need to move then the boot opens
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline sootpig
« Reply #3 on: April 22, 2014, 08:18:20 pm »
Just changed back to mk5 handle and rechecked wiring.  meter testing tomorrow to find voltage errors
 Thanks for the replies :happy2:
Offline Pikey Motorsports
« Reply #4 on: April 29, 2014, 04:24:26 pm »
Are your rear indicators working
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline sootpig
« Reply #5 on: April 29, 2014, 05:51:05 pm »
 Yes. :happy2: al lights are  working. Only fault is the op scan error code Triple checked wiring from hatch to C pillar both sides
 May get a chance to investigate at the w/end.
