Author Topic: Heated seat retrofit... what a mare!!!! Any help? lol  (Read 7969 times)
Offline skard
  • -Receive: 245
Re: Heated seat retrofit... what a mare!!!! Any help? lol
« Reply #15 on: April 22, 2014, 11:19:54 am »
On LHD the nearside seat is the master.
On RHD the nearside is still the master, but our CECM and fusebox is on the opposite side.
Thus, you swap the seat looms over to fool the car into thinking it is LHD effctively.
OR you cut the big fat plugs from the Kufatec loom, and swap them over (which means about three wires need extended from one side to the other as the master plug has more pins) to make it how it should come for a RHD car.
I complained to Kufatec about this once before but still they only make LHD looms.
It won't work with your current configuration, sorry.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #16 on: April 30, 2014, 06:09:03 pm »
Xjay, did you get anywhere with this? Do the comments make sense after you check your wiring?
VCDS (Preston, Lancashire)
Offline xjay1337
  • -Receive: 377
« Reply #17 on: May 01, 2014, 01:53:28 am »
Hi mate.
Sorry, thanks for following up.
I've been so very busy at work due to ongoing projects and working the detailing aspect as well, I'm literally only at home to sleep these days.
Jairm and I are gonna have a bash at doing the door speakers soon so what I'll do is ensure that I check it out properly then - I suspect swapping the seat looms over should / would hopefully resolve the issue?
Skard's explanation along with the input from yourself and others does make sense :)
I just need to check for these modules under the seats and go from there  :drinking: :drinking: :drinking:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #18 on: May 01, 2014, 07:18:49 am »
I know the feeling lol.
Where abouts are you? I could pop over n take a look. You're probably down south somewhere! I'm in Lancashire.
Offline xjay1337
  • -Receive: 377
« Reply #19 on: May 01, 2014, 10:08:01 am »
I am down south, haha. Newbury here.
When Jairm and I work on the door speakers I'll have a look then, only takes 15 mins to take the seats out.  :happy2:
