Author Topic: please advise me  (Read 3931 times)
Offline denzilbud
please advise me
« on: April 24, 2014, 07:48:53 am »
Hi all owned my 07 plate gti for a couple of months and already had complete meltdown of number 2 ignition coil, a rear door that wont open, a bust dv,since replacing the dv with a revision g the car feels slow,and generally doesnt feel like it used to is the revised dv compatible with my bwa engine. Many thanks in advance
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
Re: please advise me
« Reply #1 on: April 24, 2014, 11:18:12 am »
Your rear door not opening is the door lock module failure common on MK5's. Have you replaced the ignition coil or only fitted the revision G?
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline denzilbud
« Reply #2 on: April 24, 2014, 01:12:43 pm »
Changed all coils and dv for g also does anyone know what the part numbers are for the revised pcv for a bwa engine with ķ03
Offline mdmay
  • -Given: 38
Re:
« Reply #3 on: April 24, 2014, 02:02:02 pm »
I would have a look at the state of the plugs in there as well
Sent from my GT-I9505 using Tapatalk
Regards,
Mike
Offline denzilbud
« Reply #4 on: April 24, 2014, 05:46:25 pm »
It had a major service including plugs before I got it would the coils going affect the plugs?
Offline doylebros
  • -Receive: 310
« Reply #5 on: April 24, 2014, 08:23:22 pm »
Read though these
http://www.mk5golfgti.co.uk/forum/index.php/topic,52731.0.html
The advice within will answer most of your question with detailed how too's  :happy2:
Offline doylebros
  • -Receive: 310
« Reply #6 on: April 24, 2014, 08:39:54 pm »
From 01/02/2014
06F 129 101 R pressure relief valve £38:69 full retail inc vat @ TPS or your VW dealers.
Offline denzilbud
« Reply #7 on: April 24, 2014, 09:08:33 pm »
manythanks is there a gasket and pipe I need aswell if anyone has the part numbers for those
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 249
« Reply #8 on: April 24, 2014, 09:14:25 pm »
Wouldn't bother with the pipe. The gasket is part of the PCV unit
Offline doylebros
  • -Receive: 310
« Reply #9 on: April 24, 2014, 09:19:49 pm »
Look here
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1728&ein=2007&f=474&hauptgr=1234567890&hg=1&grf=010380409&bf=10380&hgug=103&ug=03&parent_id=2335052
Item 18 is the valve priced above
19 - is the gasket / oring - £20:14
4  - vent hose  06F 103 221 E - £ 20:63
5 - breather line 06F 103 235 - £17:76
Normally you only change the valve and oring. :happy2:
« Last Edit: April 24, 2014, 09:21:35 pm by doylebros »
Offline denzilbud
« Reply #10 on: April 24, 2014, 09:32:33 pm »
Thankyou all for your help can get that orderd now
Offline mdmay
  • -Given: 38
Re:
« Reply #11 on: April 24, 2014, 11:28:49 pm »
Check them anyway mate as a lot dealers are complete bellends. The service life of the standard plugs is supposed to be 40k but I have always checked mine every service
Regards,
Mike
