Author Topic: Belt squeal - help  (Read 4271 times)
Offline Itguy
Belt squeal - help
« on: April 24, 2014, 05:38:59 pm »
Hi everyone
Have noticed that our gti has started squealing the six aux belt a bit when pulling away from standstill with the air con on and working hard.
It's a dsg (if that matters) and I changed the belt (not tensioner) about 3 months ago. If I switch the air con off the squeal stops/doesn't happen.
When it does squeal it's only for a second then it stops, but it sounds bad though.
I've tried some belt slip spray this morning but hasn't really seemed to help although it's very hard to spray the inside of the belt easily.
I also had my air con compressor replaced under warranty last year, around November time.
Any other thoughts? Tensioner need replacing maybe?
Offline skard
  • -Receive: 245
Re: Belt squeal - help
« Reply #1 on: April 24, 2014, 05:41:05 pm »
I'd look at the alternator clutch pulley too
Offline Itguy
« Reply #2 on: April 24, 2014, 05:47:20 pm »
Ok - is there an easy test for it to see if it's good?
I'd kind of ruled it out as the belt/pulley is silent when the aircon is off - is this a mistake?
Offline skard
  • -Receive: 245
« Reply #3 on: April 24, 2014, 05:56:59 pm »
It should only spin one way, I changed mine as a matter of course when I got the car.
On a previous car I had a rumble at tickover, putting aircon on changed the noise, it was the clutch pulley.
Does it have a genuine belt on? Only mentioning as I have had them from motor factors before and they are 5mm longer for instance.
Offline Itguy
« Reply #4 on: April 24, 2014, 06:17:03 pm »
Interesting - I don't think it is a genuine belt, no. Can't remember what make it is, I think I picked it up off ebay.
Well if the belt is coming off for me to test the pulleys then I will fit a new belt too - got to pop to the dealers for something else too.
Offline doylebros
« Reply #5 on: April 24, 2014, 07:08:11 pm »
As he says ^^^^+ watch this
http://m.youtube.com/watch?v=fyosuYbPxr4
Offline Itguy
« Reply #6 on: April 24, 2014, 07:42:14 pm »
Nice one, I'll check this out on ours. I did actually notice our tensioner moving up and down a bit and I was thinking I'm sure that doesn't look normal.
Could well be the answer
