Author Topic: NQSBBK squeal  (Read 1273 times)
Offline Donx22
NQSBBK squeal
« on: April 24, 2014, 06:53:07 pm »
Has anyone got any advise on brake squeal.
Running standard brembo discs with the 7x1mm removed from both sides and standard textar pads with backing pads from ECP and I has squeal at horrific squeal at all speeds and levels of braking. Stops on a penny but now it's starting to my head in!  :scared:
Do I need a pad with a higher carbon content? Use pagid or something? Any suggestions would be greatly appreciated!
Re: NQSBBK squeal
« Reply #1 on: April 24, 2014, 08:01:16 pm »
Go for a run and do a few hard stops from around 80mph to around 10 mph without activating your abs. Once you start feeling brake fade let them cool for half an hour.
Offline Donx22
Re: NQSBBK squeal
« Reply #2 on: April 24, 2014, 09:25:21 pm »
ok il give it a shot,  :happy2: I did bed them in slowly, waiting a few 100 miles doing gentle driving and then starting using them hard.
Seems to be more low G brake stops that makes them squeal, you can make it stop but applying a harder brake pressure but its not great with ppl behind!
Offline Donx22
Re: NQSBBK squeal
« Reply #3 on: April 24, 2014, 09:35:17 pm »
above when i said backing pads i meant the shims that go into the piston and stick to the pas, should i be using the anti squeal shims also? or do i need to get shims form Porsche themselve, does anyone else seem to have the issue with the euro car parts pad backing?>
Re: NQSBBK squeal
« Reply #4 on: April 24, 2014, 10:23:30 pm »
The ecp dampers should work as well as the genuine Porsche ones.
