Author Topic: Help Retro fit headlamp washers  (Read 2112 times)
Offline V2 FAN
  • Porsche 911 inbound
« on: April 24, 2014, 08:03:23 pm »
Hi Guys,
Just had a horrible thought.
I've recently purchased some delicious Xenons and I will be looking at getting the headlamp washers fitted.
Do I need a new bumper  :sad1: or does the cap on my existing bumper just need changing?
I've ordered new headlamp washer caps from VW and these are being colour coded to suit my existing bumper.
I'm keeping my fingers crossed that this is simply a case of swapping the caps over.
Any pointers much appreciated  :happy2:
Offline SI-R32
  • -Receive: 126
Re: Help Retro fit headlamp washers
« Reply #1 on: April 24, 2014, 08:06:42 pm »
Evening Jake, as the GTI can have xenons as an option there is no extra bumper numbers in ETKA for this so that means should be easy fit inside your bumper with just the correct bits
Si
Offline skard
  • -Receive: 245
« Reply #2 on: April 24, 2014, 08:19:46 pm »
I retrofitted them on my old car, replace the single moulding with a two piece one (smallest one pops out with washer). All the cable routing tabs and mounting points are already there
Offline V2 FAN
« Reply #3 on: April 24, 2014, 08:40:43 pm »
Thanks Guys
Was a panic moment !
I couldn't be doing with the additional expense  :happy2:
Offline ColinMk4
« Reply #4 on: April 24, 2014, 08:52:01 pm »
How much does it cost to do retro fit this?
Offline skard
  • -Receive: 245
« Reply #5 on: April 24, 2014, 08:54:26 pm »
It cost me a couple of hundred quid combining used and new bits
Offline V2 FAN
« Reply #6 on: April 25, 2014, 09:13:45 am »
I'll keep you updated if you like.
I have another thread which lists all the parts but like Skard said it cost him a few quid and there's the expense of fitting  :sick:
Offline skard
  • -Receive: 245
« Reply #7 on: April 25, 2014, 09:30:03 am »
Fit it yourself mate, the hardware is straightforward, I routed it like this http://forums.vwvortex.com/showthread.php?4146014-Few-shots-from-headlight-washers-retrofitting
If you buy the 5.5L bottle from VW/TPS it should come with the additional holes bored out already. The trickiest part is the loom which needs fed from the engine bay into the CECM, fusebox and instrument cluster (if you want low level fluid warning), but even that is no problem  :happy2:
Offline V2 FAN
« Reply #8 on: April 25, 2014, 09:37:21 am »
Thanks mate
I'll certainly research this  :happy2:
Bloody Xenons lol
