Author Topic: Large & Small Paint Chip Removal  (Read 2538 times)
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« on: April 25, 2014, 09:24:16 pm »
Has anyone got any links to videos that are specific to the VW Mk5 Golf or VW paint that shows what kits to use and also how to use them in the best possible way as i have a few chips i would like to have a go at removing without having a full panel respray.
Offline CarlW
Re: Large & Small Paint Chip Removal
« Reply #1 on: May 02, 2014, 03:36:19 pm »
Anyone?....  :smiley:
Offline Chris92
  • -Given: 33
« Reply #2 on: May 02, 2014, 11:17:08 pm »
http://www.detailingworld.co.uk/forum/showthread.php?t=20127
That's looks like a good guide, I'm going to attempt this method on a old panel and see how it goes.  :happy2:
Offline CarlW
« Reply #3 on: May 04, 2014, 03:00:54 am »
Appreciate that Chris.. You using the site used in that thread he has used?
Would you be kind enough to update me with your results if and when you do it? it would be very much appreciated :happy2:
Offline Chris92
  • -Given: 33
« Reply #4 on: May 05, 2014, 11:13:51 pm »
Yes I'm on that site, it's got a lot of info on and has helped me many of times  :happy2: .
Yes I will update on this method when I get round to it, I've just order my first DA polisher with different pads and compounds etc so when I get a chance this summer ( hopefully soon) il correct the paint on my car then il have a go at fixing some stone chips on a old panel before I attempt this on the car.
Offline CarlW
« Reply #5 on: May 06, 2014, 08:24:43 pm »
Spot on :happy2: look forward to seeing some results :smiley:
Offline swgti
  • -Given: 28
« Reply #6 on: May 08, 2014, 03:26:13 pm »
I'm looking at the Chipex system, looks a lot easier and I do not like the idea of the wet and dry process of the paints 4 u system, it's a little bit dearer at £39 for a kit that will do a badly chipped car.
Offline CarlW
« Reply #7 on: May 09, 2014, 08:18:41 pm »
If you order.. is there any chance of a few before and after shots when you get round to doing it?
Offline swgti
  • -Given: 28
« Reply #8 on: May 11, 2014, 08:09:41 am »
Yeah will do, not sure when it'll be though.
Offline Jct 1991
« Reply #9 on: June 24, 2014, 06:09:54 pm »
Think ill give this a try
Offline CarlW
« Reply #10 on: June 27, 2014, 01:37:36 am »
Totally forgot about this thread.. If you do try this, be sure to post some pictures of your results and name products used etc :happy2:
