Author Topic: Must Watch!!! - Sway / Anti-Roll Bar Science  (Read 1752 times)
Offline GTI-Ross
  • Learning All The Time :)
« on: April 25, 2014, 10:55:41 pm »
Definitely worth a watch (watch till the end):
I have just bough 28mm / 24mm bars  :confused:
« Last Edit: April 26, 2014, 10:09:04 am by GTI-Ross »
Offline Markyed30
Re: This has now baffled me !!! - Watch this Sway / Anti-Roll Bar Science
« Reply #1 on: April 25, 2014, 11:15:27 pm »
That's nuts I had an rx8 with a snapped droplink come mot time how long it was snapped I don't know only had it 9 months and handled fine  :confused:
Offline GTI-Ross
« Reply #2 on: April 26, 2014, 10:08:43 am »
Just shows then. Well ill just stick with the main stream for now.
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
Re: Must Watch!!! - Sway / Anti-Roll Bar Science
« Reply #3 on: April 26, 2014, 10:21:26 am »
Air suspension car owners will love this  :signLOL:
Instagram: stu_nc88
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=jq3nslov7e21429srfhqtk3eks&/topic,19740.0.html
« Reply #4 on: April 26, 2014, 10:44:37 am »
Well.... this is a bit more complex than just "remove your ARBs and you will get more grip"
Offline biffobear
« Reply #5 on: April 26, 2014, 11:42:43 am »
Very interesting, he's right about the compression on dampers on one side affecting the other side ( causing wheel lift) when cornering. The only way to get true independent suspension would be to either, A, remove anti-roll bars and have well set up springs and dampers or B, torsion bar anti-roll bars, 4 of, which work independently of each other , anyone removed anti-roll bars and tried it?
Offline betty_swollox
  • -Receive: 29
« Reply #6 on: April 27, 2014, 12:34:47 am »
Was so boring  :booty:
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline xjay1337
  • -Receive: 377
« Reply #7 on: April 27, 2014, 02:12:29 am »
Offline metaljay
  • Scirocco R Owner
« Reply #8 on: April 27, 2014, 08:54:24 am »
I literally have just been looking to buy a set. I shouldn't watch videos like this, confuses me haha
Offline GTI-Ross
« Reply #9 on: April 27, 2014, 10:41:14 am »
I think it only applies if you have hours to adjust your shock setting, damping, rebound, stiffness etc..
For most people they saying adding decent stiffer roll bars makes the world of difference. I dont have hours and hours. So stiffer sway bars for me :happy2:
