Author Topic: misfire count  (Read 4863 times)
Offline bower
misfire count
« on: April 26, 2014, 02:34:09 pm »
hi ive just checked my misfire count on vcds and i recorded a 4 misfires under load on cylinder one and i wondered if this it anything to worry about?
Re: misfire count
« Reply #1 on: April 26, 2014, 02:49:38 pm »
Could be an indication of needing new plugs or coilpack within the troubleshooting list..
Offline bower
Re: misfire count
« Reply #2 on: April 26, 2014, 03:00:53 pm »
ive just recently changed the plugs.
so its not an acceptable misfire then?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: misfire count
« Reply #3 on: April 26, 2014, 09:01:43 pm »
Misfires are not acceptable, period.
Mine started on one cylinder a few months back, was a dying coilpack. Swap coilpacks with another cylinder and see if it follows the coilpack
Offline mvb12
  • -Receive: 64
Re: misfire count
« Reply #4 on: April 26, 2014, 09:37:45 pm »
I would just change all the coil packs.
heard the red tops give you added bhp  :laugh:
Offline betty_swollox
  • -Receive: 29
Re: misfire count
« Reply #5 on: April 27, 2014, 12:27:07 am »
Yeah misfires are normal mate, definitely something that's 'acceptable'
Fuuuuuuck me lol
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline DanGB
  • Different
Re: misfire count
« Reply #6 on: April 27, 2014, 12:41:31 am »
Misfires actually happen on standard cars out of the factory. But a count of 4 is a bit too high on one cyl.
Seat Leon Mk2 TFSI sport 4WD sleeper - Breaking
Buld thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,45377.0.html
Offline robdf2
Re: misfire count
« Reply #7 on: April 27, 2014, 09:49:29 am »
It depends on whether your car was warm or the count was done straight from a cold startup?
Believe it or not I had over 25 counts and seat said it was normal !
2008 Chrono yellow Cupra
Offline bower
Re: misfire count
« Reply #8 on: July 13, 2014, 05:01:48 pm »
resurrecting my post because the problems still there and i dont know where to go from here.
when start up from cold, i get shaking going through the car in high gears (4-6) at 2k revs, if i put the foot down it doesnt do it but cruising it does.
ive changed the coil packs, fuel filter and spark plugs but the problems still the same if not worse. ive done a vcds scan today but no errors and i also did a live data collect and it was misfiring on cylinder one, upto 6 misfires.
the strange thing is when it gets up to temp it stops shaking?
where to go from here? is it an injector? anything i can check on vcds?
thanks for any help
Offline martin@gti.co.uk
Re: misfire count
« Reply #9 on: July 13, 2014, 05:25:33 pm »
might be the injector or carbon build up on intake valves.. try different injector first..have a look on the gap on spark plug again and check wiring sockets for corrosion etc.. Hope you get it sorted mate.
also if you can do logging
use APR page for this:
Misfire-Specific Diagnosis
Item #   Vag-Com
Block #   Description
1   001-1   Engine Speed
2   003-2   Intake Air Mass
3   015-1   Misfire Cyl 1
4   015-2   Misfire Cyl 2
5   015-3   Misfire Cyl 3
6   016-1   Misfire Cyl 4
7   054-3   Accelerator Pedal Position
8   054-4   Throttle Plate Angle
9   101-3   Injection Timing (Median)
10   115-3   Boost Pressure (Specified)
11   115-4   Boost Pressure (Actual)
12   230-2   Rail Pressure - Actual
« Last Edit: July 13, 2014, 05:29:58 pm by martin@gti.co.uk »
Offline bower
Re: misfire count
« Reply #10 on: July 13, 2014, 05:33:46 pm »
cheers for that  :happy2: just wish it was easy to swap the injectors, if i have to strip it all to get to it i may aswell just put a new injector in.
i have looked at those on vcds but it may aswell be in a different language lol
Offline bower
Re: misfire count
« Reply #11 on: July 13, 2014, 06:01:14 pm »
anyone tried bg44k injector cleaner or is it the same rubbish as redline?
also if i use the wynnes egr cleaner do i have to do an oil change?
Saintsteve
Re: misfire count
« Reply #12 on: July 13, 2014, 06:21:31 pm »
Replace the injector on the effected cylinder.Carbon build up being the main cause. clean the others and replace the duff one to cure .
That will cure your issue.
Extremely common fault on cars over 60k and getting more and more common.
Offline bower
Re: misfire count
« Reply #13 on: July 13, 2014, 06:24:54 pm »
mines on 108k so im guessing thats the problem
is there a how to replace the injector?
Saintsteve
Re: misfire count
« Reply #14 on: July 13, 2014, 06:29:03 pm »
Perhaps check on you tube for how to replace injector on 2.0TFSI.
I gave my car to JKM to sort.
