Author Topic: misfire count  (Read 5236 times)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: misfire count
« Reply #15 on: July 13, 2014, 09:43:37 pm »
mines on 108k so im guessing thats the problem
is there a how to replace the injector?
Perhaps check on you tube for how to replace injector on 2.0TFSI.
I gave my car to JKM to sort.
You need a special tool to remove TFSI injectors. Looks like a pig of a job  :sad1:
Offline bower
Re: misfire count
« Reply #16 on: July 13, 2014, 09:49:05 pm »
great  :scared: whys this car so hard to work on!
Offline bower
Re: misfire count
« Reply #17 on: July 13, 2014, 10:26:04 pm »
want to try the wynnes egr cleaner but just changed my oil, so if i do use it do i have to change the oil again?
Saintsteve
Re: misfire count
« Reply #18 on: July 14, 2014, 02:06:49 pm »
Tried it, didn't work, helped but missfire comes back.
And no you don't need an oil change
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: misfire count
« Reply #19 on: July 14, 2014, 02:16:59 pm »
Try BG44k just before you change the oil again.
Tbh running a can through midway between oil changes won't do any harm, it's just not a good idea to run lots of injector cleaner bottles through the system.
Offline bower
Re: misfire count
« Reply #20 on: July 14, 2014, 07:25:09 pm »
thanks for your help  :happy2: seemed slightly worse on way home from work  :scared:
