Author Topic: RNS510 Security code and volume control issues  (Read 1433 times)
Offline Rob GTI
« on: October 15, 2009, 07:54:07 pm »
Just had my RNS510 delivered and have discovered the following issues:
1. The volume cannot be adjusted, it is set to a very low level and will not turn up or down, (the mute symbol is displayed on the screen as well).
2. The unit asks for the security code each time I power the unit on.
The unit appears to be firmware revision A.
Any ideas?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Re: RNS510 Security code and volume control issues
« Reply #1 on: October 15, 2009, 08:07:24 pm »
Have you got a bluetooth car kit installed?
Offline Rob GTI
« Reply #2 on: October 15, 2009, 08:26:20 pm »
No just the RNS510, I have tried another one in the car before (Rev B FW) and that worked fine.
« Reply #3 on: October 15, 2009, 08:59:34 pm »
Rob, take the unit out, turn it round and make sure all the pins are straight and haven't been bent during installation. You might have a short causing the unit to think it's receiving a mute signal from that pin
Offline Rob GTI
« Reply #4 on: October 16, 2009, 09:44:16 pm »
The pins weren't damaged, but after I left the unit for an hour or so after posting the problems they rectified them all by themselves??? and have been fine ever since.
Offline Jamerson
« Reply #5 on: January 21, 2012, 10:31:54 pm »
i remeber i had the same issue with my B unite, but after couple of hrs it fix it self,
someone the parts need to see each others,
