As part of the special offer that Nick and myself run for this forum
www.mk5golfgti.co.uk/forum/index.php/topic,80983We were very excited to get Mandy's lovely Golf R in for a long days work.
Mandy was so very kind to bring us a massive box of biscuits, which definitely kept us going through the 15+ hour day. It's very rare we get given little treats like this so was really kind, and will keep us well fed for many weeks to come, haha.
IMG_4655 by
Fat Bear Photography, on Flickr
Anyway, all fun aside here's how the car was delivered to us at around 8:45am :)
IMG_4641 by
IMG_4643 by
IMG_4646 by
IMG_4650 by
So definitely in need of a good wash!
For this we used Valet Pro Citrus Prewash sprayed liberally onto the wheels and lower panels of the car, using a dual action sprayer and then jetted it off (the wheels only) revealing a wheel 90% clean, as the wheels have recently been refurbished in a lovely anthracite colour which really matches the car.
IMG_4654 by
IMG_4657 by
To get them spotless, Meguiars Wheel Brightner was used at a low dilution ratio
Meguiars sidelock brushes and EZ-Detail wheel brushes were also used to get all the way to the back of the barrel. The arches were cleaned using APC, wheel cleaner and various wheel woolies, and Iron X was also applied to the wheels to remove bonded iron contamination.
IMG_4671 by
While I was getting on with this Nick coated the car with Bilt Hamber Autofoam to loosen off the dirt prior to being washed with the usual 2 bucket method with DMC Ultra Gloss Shampoo and DMC's lambswool wash mitt.
IMG_4667 by
IMG_4669 by
While the Autofoam was doing it's job Nick went round the car with another Megs Sidelock brush and some diluted APC cleaning off the grills, door rubbers, fuel cap, etc.
IMG_4670 by
After washing:
IMG_4674 by
IMG_4673 by
After this step we began decontamination of the paintwork - Iron X was applied to the whole vehicle and then rinsed, after that Autosmart Tardis (in the Body solvent bottle) was used on the lower halfs of the car and any tar spots were wiped away with a microfibre towel and then the car was jetted off thoroughly to remove any left over product from the surface.
IMG_4677 by
IMG_4678 by
IMG_4679 by
The engine bay was cleaned at this stage as well, using APC and a variety of brushes, before being carefully jetted off and dried, with a durable protective coating applied.
IMG_4683 by
IMG_4686 by
IMG_4688 by
The car was now dried using Uber XL Microfibre drying towels and the crevices blown out using a heated electric pet drier and taken into the unit to begin inspections and taping up the car ready for polishing.
Before any polishing work commended the car was given a good check over using the paint depth gauge to measure remaining clearcoat.
IMG_4726 by
IMG_4733 by
IMG_4737 by
IMG_4734 by
After a visual check of the car with Brinkman LED & Halogen lights , there were several deeper scratches on certain panels, mainly the rear passenger side wing and the roof which suffered from some seriously heavy and deep swirling.
Some just under what little sunlight we could get throughout the day of heavy showers!!
IMG_4741 by
IMG_4746 by
IMG_4753 by
IMG_4756 by
IMG_4758 by
Generally healthy levels of paint depth were measured as expected for a VAG model however there were some areas of concern, especially on the lower half of the drivers side wing which in places was reading as low as 71 microns of paint!!!! I was surprised there was any clearcoat left!!
IMG_4817 by
This area of low paint readings carried on about half way along the drivers door, under the lower swage line - To avoid any possible strike through to these areas the areas were completely taped up and not corrected (they would later be given a very light polish as part of the refinement process).
Polishing began with Nick and I taking a side each and working along the car.
As typical with German paint, and similar to a Mk6 GTI that Nick has done in the past, the paint was incredibly hard meaning that swirlmarks take multiple passes to achieve a good 85% defect removal rate.
Please note all of the after shots are taken after an IPA wipedown but BEFORE refinement, as we correct the car first and then refine it after removing the dust. Just makes tidying up easier and means any minor marks inflicting by removing the dust if you were really unlucky, can be easily removed. Some of the defects are hard to photograph!
Drivers side wing:
Before
IMG_4763 by
After
IMG_4768 by
Drivers door 50/50, left hand side uncorrected right hand side corrected.
IMG_4775 by
Rear drivers side door before:
IMG_4782 by
and after
IMG_4787 by
Rear passenger 3/4 panel before:
IMG_4791 by
and after
IMG_4793 by
