Author Topic: New Thermostat Needed? | Solved  (Read 12184 times)
Offline alexmccabe
    • Alex McCabe
« on: April 28, 2014, 08:47:07 am »
Right guys, advice please :)
My car temp sits at 75º instead of the 90º that it should be. Would this be the thermostat?
« Last Edit: May 03, 2014, 01:41:34 pm by alexmccabe »
MK5 Golf GTi 197BHP Tornado Red
Offline skard
  • -Receive: 245
Re: New Thermostat Needed?
« Reply #1 on: April 28, 2014, 08:50:30 am »
It was on my ED30. If after 10 minutes of driving it is not at 90c & fluctuating when you stop/move off, then it is a safe bet.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: April 28, 2014, 09:49:45 am »
My issue here:http://www.mk5golfgti.co.uk/forum/index.php/topic,80793.0.html
Was fixed with a new thermostat  :happy2:
It's a pig of a job to do at home, your best going to a specialist.  Part is around £25 IIRC
  • -Receive: 453
« Reply #3 on: April 28, 2014, 09:58:45 am »
Offline alexmccabe
    • Alex McCabe
« Reply #4 on: April 28, 2014, 10:59:02 pm »
Cool thanks guys. I thought as much. Does anyone have a part number for it, I read on that thread that it was a specific on for an Ed30, but mine is just a normal GTi.
Offline skard
  • -Receive: 245
« Reply #5 on: April 28, 2014, 11:23:22 pm »
The GTI has a different part number, think it ends F not H but have a look to confirm that.
Offline alexmccabe
    • Alex McCabe
« Reply #6 on: April 29, 2014, 09:34:09 am »
06F 121 111 F
Does this look right to you? It's all I can find.
Offline skard
  • -Receive: 245
« Reply #7 on: April 29, 2014, 12:31:05 pm »
Yes for a GTI, or part number ending H not F for an ED30
Offline teginder81
« Reply #8 on: May 01, 2014, 12:17:43 pm »
The problem is that the gauge may be inaccurate, that is very cold for an engine temp. If the gauge is correct you may have a thermostat stuck in the open position. If this is indeed the case you had better change it as your engine mixture depends on proper engine temp.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #9 on: May 01, 2014, 12:24:24 pm »
The gauge IS inaccurate. Best doing the trick with the climate to see what the sensors are reading. 75 degrees on the gauge will be around 60ish degrees in the climate display
Offline skard
  • -Receive: 245
« Reply #10 on: May 01, 2014, 01:22:58 pm »
Should say I diagnosed mine off the Fiscon readings, the gauge first gets to 90c when it is about 75c
Offline alexmccabe
    • Alex McCabe
« Reply #11 on: May 02, 2014, 09:25:49 am »
Okay, so how do I go about getting this to appear? I'm assuming it is on the climate control displays?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #12 on: May 02, 2014, 12:21:37 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,80793.msg839035.html#msg839035
Offline alexmccabe
    • Alex McCabe
« Reply #13 on: May 03, 2014, 01:41:18 pm »
Perfect thank you! Using that and speaking to my mechanic on the phone, I do indeed need a new thermostat. Thanks everyone!  :smiley:
« Last Edit: May 03, 2014, 09:49:27 pm by alexmccabe »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: New Thermostat Needed? | Solved
« Reply #14 on: May 03, 2014, 03:29:27 pm »
^ found your post in the middle of those quotes  :signLOL:
Glad your getting it sorted mate  :happy2:
I feel sorry for your mechanic, he is going to hate you  :ashamed:
