Author Topic: AUX ?  (Read 3067 times)
Offline Jams1231
AUX ?
« on: April 28, 2014, 07:29:59 pm »
Hi guys any ideas where my AUX is says ive got it but cant find it?
Pic of my head unit :
Offline Legend
Re: AUX ?
« Reply #1 on: April 28, 2014, 07:42:17 pm »
There is a possibility that the headunit has one built in but it was put in afterwards unless you can tell us otherwise? If it was put in after the initial set-up, the person may have not retrofitted an AUX port into the car despite it having a connection. To complete the set-up, you will need to buy a socket and wire to plug it into the back of the headunit and into one of those blank buttons beside the gear stick.
Aye, that wan.
Offline JaseGti
    • Remoteclothing
Re: AUX ?
« Reply #2 on: May 02, 2014, 10:38:18 am »
Anything in the centre console or glove box?
CW is the way forwards
Remoteclothing.com
Offline Haz911
Re: AUX ?
« Reply #3 on: May 02, 2014, 03:07:19 pm »
Should be in the centre console or glove box, if not then highly likely it is built into the headunit and you will need to run a lead from the back....
2007 Tornado Red 3dr Edition 30 - Stage 1
1998 Polo 6n 1.8 20vt - 262 bhp
Offline bluo
Re: AUX ?
« Reply #4 on: May 02, 2014, 08:58:12 pm »
When you say, "it says I've got one but can't find it" do you mean you have the AUX button on the radio and can't find the female jack plug?
I fitted mine last year, it too months to find the right kit and then also work out how to mod the plug on the back of the radio but got there in the end.
Here's the part number for the kit... 1k0998940
Comes with aux plug, wire harness and socket that replaces the glove box light but you can be creative and mount that somewhere else!
I just lost the glove box light and put it there.
Offline Legend
Re: AUX ?
« Reply #5 on: May 02, 2014, 10:01:36 pm »
30 minutes of DIY work for me, I had never even touched my car prior to this!
Aye, that wan.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: AUX ?
« Reply #6 on: May 03, 2014, 11:22:59 pm »
That AUX switch will not work with the MFD2 :(
Offline Legend
Re: AUX ?
« Reply #7 on: May 04, 2014, 01:55:04 pm »
Ah, I installed it when I was changing over my RCD210 to RCD310.
Aye, that wan.
