Author Topic: Engine Bay  (Read 3732 times)
Offline ILoveTuna
Engine Bay
« on: April 28, 2014, 07:51:00 pm »
Hi chaps,
My engine bay is looking like is desperately needs a spruce up.
What products/process would you recommend?
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
Re: Engine Bay
« Reply #1 on: April 30, 2014, 02:18:41 pm »
AutoGlym Engine and Machine Cleaner does the job. :happy2:
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline xjay1337
  • -Receive: 377
Re: Engine Bay
« Reply #2 on: April 30, 2014, 02:46:12 pm »
Start the car.
Clean it with brushes, APC, degreaser products.
Jet off thoroughly.
Leave running for 10 minutes.
Apply your sealant usually a spray one and follow the usage instructions.
Offline ILoveTuna
Re: Engine Bay
« Reply #3 on: April 30, 2014, 07:15:14 pm »
Thanks chaps project for the weekend.  :happy2:
Offline greygti
Re: Engine Bay
« Reply #4 on: May 04, 2014, 11:04:57 am »
APC ,brushes and a handheld steam cleaner works for me
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
Re: Engine Bay
« Reply #5 on: May 09, 2014, 08:20:31 pm »
Anything you need to be wary of when using water / products around the engine? any wires / battery etc to cover up with some tarp or anything?
Offline xjay1337
  • -Receive: 377
Re: Engine Bay
« Reply #6 on: May 09, 2014, 09:43:05 pm »
Nope if you have all the battery and fuse box covers you are fine to go.
Offline gti265
Re: Engine Bay
« Reply #7 on: May 19, 2014, 12:09:20 am »
Just obviously dont point a jet wash at the fuse box for 10 mins and expect it to stay dry insude, but a quick rinse with hose or jet wash will be fine as its all relitavly water tight, just remember if you start the engine dont put fingers in fans etc if its hot enough for them to turn on ;)
Friend learnt the fard way by putting engine on and loosing his sponge in the cambelt, nearly his fingers 2  :congrats:
Tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline jocco
Re: Engine Bay
« Reply #8 on: May 19, 2014, 02:33:23 pm »
I think its rediculauss and dangerous to wash an engine while its running.
The way I do it, I get it warmed up, turn off, clean, dry as much as you can and then start the engine and let it idle for 10-15 min.
Offline DanMaytee
Re: Engine Bay
« Reply #9 on: May 19, 2014, 03:18:07 pm »
Why is it? Surely as long as you aren't squirting water into the intake you're fine.  I've done it plenty of times with the engine running and not had one problem.  I did avoid the battery, fuse box and alternator though.
Offline DDM
Re: Engine Bay
« Reply #10 on: May 19, 2014, 03:48:10 pm »
only thing i'd avoid is doing it whilst the engine is warm, i've found it can ruin the alternator bearings by blasting it with cold water whilst hot.
Offline jocco
Re: Engine Bay
« Reply #11 on: May 20, 2014, 02:24:11 am »
If I do it on a warm engine i dont actually use running water from a hose or a pressure washer. I use engine clean or degrease products on a towel, sponge or a brush.
I have pressure washed few engines and its always been on a cold engine. But it takes too long to dry it and at the end I still have to use a sponge or a brush to get all the dirt out.
