Author Topic: Michelin Pilot Super Sports  (Read 64901 times)
Offline flashp
  • -Receive: 65
« on: April 29, 2014, 12:05:42 am »
After several weeks waiting, well about 6 actually, they turned up straight from the factory.
They're not particularly cheap at £575 fitted but I was looking for a tyre that was capable of occasional track days that wouldn't get out of it's depth on circuit and would also deliver good performance on the road in most conditions. I considered the usual suspects that are track focused but road legal but kept coming back to these and decided to wait for Michelin to deliver.
Delays were down to this being a new size/specification as until recently it's been supplied to Porsche, Ferrari and BMW predominantly and I believe sizes now start at 18".
To drive on they are significantly different. I have to consider that I have had them fitted to wheels that are 3kg lighter than the Pirelli alloys (which weigh in at 11kg and are very front heavy) but the grip levels are vastly improved in the dry and particularly the wet. Steering sensitivity (and weight it feels) is improved, as is turn in due to stiffer side walls I'd imagine.
Sudden increases in torque are also better managed in all conditions from low speeds. Braking levels are also higher (in the wet at least) before ABS intervention.
I can't say that F1's were a bad tyre at all, but for a stage 2+ vehicle I rate these very highly. Very happy with them indeed. Not unhappy with the wheels either, I shamelessly followed Red Robins lead here.  :star:
Gone but not forgotten :-)
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: Michelin Pilot Super Sports
« Reply #1 on: April 29, 2014, 04:39:10 am »
Liking both, the sound of the tyres and the look of the rims!  :smiley:
Offline robern2
« Reply #2 on: April 29, 2014, 04:41:20 am »
Good review I'll be buying them in the summer also.
« Reply #3 on: April 29, 2014, 07:34:53 am »
Carlo really rates these too even in 19" on the BBS
Offline Hevoshullu
« Reply #4 on: April 29, 2014, 07:41:17 am »
Slightly offtopic but did you experience the rear of your car being "flighty" or a bit loose with the Goodyear F1s (were they the Assy2's?) in comparison to other tyres such as this Michelin?
« Reply #5 on: April 29, 2014, 08:10:44 am »
How noisy are these compared with the F1s?
Offline N8KOW
  • Detailer - 2014
    • Kowalski Details
« Reply #6 on: April 29, 2014, 11:28:34 am »
Great review and again with the above, these are £133 on mytyres iirc.
2014 Mk7 Golf R on Order...
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=edrnu4rbp1qk93t2fqci4b00ei&/topic,19740.0.html
« Reply #7 on: April 29, 2014, 11:47:10 am »
Flash... Are these the extra load ones?
Offline flashp
  • -Receive: 65
« Reply #8 on: April 29, 2014, 12:52:50 pm »
These are 92Y XL rated so are a like for like replacement.
As to noise I would say that they may even be a shade quieter over certain surfaces, but are certainly no more noisy than the F1's.
The tyres they replaced were indeed asymmetrical 2's. I can't say I ever noticed misbehavior related to the back end, but I have B12 suspension and Eibach ARB's with the back set to soft and the front hard so may have negated this effect this way. Good geometry may also figure in this and your solution when you find it.
 :smiley:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #9 on: April 29, 2014, 01:51:37 pm »
I have had the 88 ones on for a while.
No need to look at anything else and at only £115 per corner from Love Tyres priced ok too
Offline N8KOW
  • Detailer - 2014
    • Kowalski Details
« Reply #10 on: April 29, 2014, 05:16:04 pm »
That's epic berg!
Offline Bignod00
  • Ginsters are sh*tE!!
« Reply #11 on: April 29, 2014, 05:20:11 pm »
I have these on all four wheels in 19" and I must say they're VERY grippy! I would say they're slightly "skittish" under hard acceleration but I'm used to that now!
 :party: :party:
Offline vRSAlex
  • -Receive: 253
« Reply #12 on: April 29, 2014, 05:29:05 pm »
Got a set sat in the corner of the workshop.  Ordered them in October, they arrived last month on 92Y.
Follow AKS tuning on Facebook
Offline tony_danza
  • -Receive: 112
« Reply #13 on: April 29, 2014, 06:01:21 pm »
I've done a couple of track days on mine now, they're stunningly capable for a road tyre.
Watch the outers, as they're softer compound and if you're not running much camber, you'll wear them out.
Sideways yo!
Offline flashp
  • -Receive: 65
« Reply #14 on: April 29, 2014, 07:02:55 pm »
Good tip, thanks. I've yet to enjoy mine on track with these. What pressure did you run? I'll have to check my geometry report and see where precisely mine was set. I know for sure I have a reasonable camber on the rear, not sure on the front without checking.
