Author Topic: Steering/handling problems  (Read 1820 times)
Offline nicky
« on: April 30, 2014, 07:03:56 pm »
Im just starting to having a problem with my ed30. When I'm sat in my car with the steering wheel straight with the car started I start to rock the steering from side to side slowly and there seems to be about an inch of play?? When I start to drive the car the steering just feels really light and unstable when trying to corner.
The car has
Anti lift kit
Coilovers
Ploy front lca bushes
New ball joints
So should really feel tight when cornering. A friend of mine said it could be the rack, he said they have valves in them that open n close when cornering and they could be sticking open when Turning or is there a steering control unit that could be playing up? Do these have power steering fluid?
Could any1 think of anything?
Thanks n advance
Offline doylebros
Re: Steering/handling problems
« Reply #1 on: April 30, 2014, 08:42:35 pm »
Well if it is the rack you want to read this:-
http://www.mk5golfgti.co.uk/forum/index.php/topic,82305.0.html
Not a straight forward issue!
Offline nicky
« Reply #2 on: April 30, 2014, 08:58:20 pm »
Had the car plugged in today but no codes  :rolleye:
Offline Donx22
« Reply #3 on: April 30, 2014, 08:59:55 pm »
I would get the car on stands get someone to hold the steering wheel while you try to work out where the play is. If you say all your components are all relatively new I would check if everything is tight under there,subframe, rack, arms, a balloonists etc, if not I sound like play in the column or UJ at the bottom of the column, 2 plastic clips behind the pedals remove the trim, you can get move wheel while looking to see if the rack moves when UJ does etc, will need 2 ppl again tho.
Rack change isn't to bad, just make sure u get the alignment done reflash at VW, charge for half hours labour to code... If they know how to do it lol
Offline nicky
« Reply #4 on: April 30, 2014, 09:19:54 pm »
Ok cheers mate il have another look, had the on the ramp 2day fitted new ball joints n bushes so everything is tight so il ha e a look behind the carpet 2moro see if I can see any play in the column
