Author Topic: Who needs the antilift kit when...  (Read 1791 times)
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« on: October 16, 2009, 03:30:32 pm »
you can go all out ...
more details soon ;)
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline Janner_Sy
  • -Receive: 113
Re: Who needs the antilift kit when...
« Reply #1 on: October 16, 2009, 04:27:20 pm »
feck me. there are a few things like this on the american market kicking about, not quite to this extreme. I wouldnt expect much in the form of reduced body roll from this, however i bet it will do well to keep the wheel geometry from changing to much
edit.... found it http://shop.foreignkoncepts.com/Ultra-Racing_c15.htm
« Last Edit: October 16, 2009, 04:32:05 pm by simonskerton »
Offline tony_danza
  • -Receive: 112
« Reply #2 on: October 16, 2009, 04:35:34 pm »
Dare I ask??
Sideways yo!
Offline Janner_Sy
  • -Receive: 113
« Reply #3 on: October 16, 2009, 04:39:02 pm »
It wont act like the WALK either.
the walk adds additional caster of 0.5degrees, as well as a stiffer bush, this in turn gives you dynamic camber on turn in(but none of the draw backs of negative camber)and  a heavier steering feel due to the additional caster.
IMO the stress bars i think would create a negligable difference in comparsion, but if you are going all out then every little counts, but I always thought that if you went to stiff on your setup(incl ARBs) it might be great in the dry but when its wet you need a degree of flex or the wheels will let go much easier
Offline tony_danza
  • -Receive: 112
« Reply #4 on: October 16, 2009, 04:45:18 pm »
The front and the middle I'd stick my neck out and say were useless. I can't see enough of the rear to decide.
The front is bolted to the subframe & chassis, so has no effect on the wishbones/uprights/engine mounts/geo... all of which cause wheel hop. So their claim there to "eliminate wheel hop" is crap.
The middle, WTF?
Sideways yo!
