Author Topic: I need you help guys with spacers  (Read 4974 times)
« on: October 16, 2009, 03:55:48 pm »
I am picking up my new brakes tomorrow,  but have a stumbling block to overcome with fitment.
To get the brakes clear of my wheels i need a 5 mil spacer. I have no spare room under my arches for a 10 mil hub centric spacer so i am needing advice on options at 5 mil.
what are your thoughts on running non hub centric are they to risky, is their any engineering solutions to this to get 5 mil hub centric. I know manufacturers would offer them if their wasn't some sort of problem in this area.
Does anyone no someone who has overcome a similar problem.  :sad1:
Offline joesgti
  • Eat my sick, Eat my sick.
Re: I need you help guys with spacers
« Reply #1 on: October 16, 2009, 03:58:54 pm »
love the sig TC, cant believe ive only just noticed!  :laugh:
Offline joesgti
« Reply #2 on: October 16, 2009, 03:59:14 pm »
oh and i have no idea  :rolleye:
Offline tony_danza
  • -Receive: 112
« Reply #3 on: October 16, 2009, 03:59:21 pm »
I've got some 5mm in the garage that have a 57.1 centre bore with the OEM taper to meet the hub perfectly. Not hubcentric, but about the best you'd get otherwise.
You're welcome to borrow them and try them.
Sideways yo!
« Reply #4 on: October 16, 2009, 04:02:25 pm »
Did you have them made Mike, and do you think they would be safe enough for track days. Once the pads are worn down some i could probably run without them on track.  :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #5 on: October 16, 2009, 04:25:28 pm »
No, just bought some centre bore specific ones rather than the universal type which can shift between the hub and wheel.
The main thing is ensuring the weight of the wheel is carried by the hub, and not the bolts. A 5mm spacer should* leave you plenty of hub to get the wheel onto.
I bought them to clear the ill fated APs with my Monzas/old track wheels, so I'd intended to use them on track.
*Assuming your new discs are no thicker than usual.
Sideways yo!
« Reply #6 on: October 16, 2009, 04:28:17 pm »
Have you spoken to Ben (Wheelman) TC?
« Reply #7 on: October 16, 2009, 04:43:16 pm »
New disks are 32 mil i believe so a bit thicker. If its ok with you Mike may i borrow them when fitting time comes around and if Dave and Votex think they will be adequate safety wise when fitting time arrives i will purchase some.  :happy2:
I was hoping he would see the thread Nath but i will PM him if not.  :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #8 on: October 16, 2009, 04:46:22 pm »
Have them as long as you want mate, they've been sat in the garage for the best part of a year - so I'm not using them.
Sideways yo!
« Reply #9 on: October 16, 2009, 04:53:11 pm »
Cheers bud.  :drinking:
Anybody else got any engineering solutions to throw into the mix.  :happy2:
Offline The wheel man
« Reply #10 on: October 16, 2009, 07:43:21 pm »
dont have that much experience with shims tbh.... i know i have them in stock 3,5 8mm but how they affect the locating of the wheel im not sure.  If the wheel was located by the spigot and all is well then i cant see the difference a shim would make (if it moved) other than making sure you have enough thread on your bolts you should be a OK  :happy2:  but what do i know, im half pi**ed  :drinking: :rolleye: :stupid:
APR cat back, ECS Insert
Offline candy turbo
« Reply #11 on: October 16, 2009, 08:36:27 pm »
if you go for 5 mm ones it leaves about 5 mm of hub left ,  a firm on ebay will make you a tapered spigot ring so the wheel will still locate on to said ring and hub , its not brilliant but it does work  :happy2:
« Reply #12 on: October 16, 2009, 08:43:55 pm »
Cheers for that Candy do you know the name of the company, its got to be worth investigating.  :smiley:
« Reply #13 on: October 16, 2009, 08:49:50 pm »
just leave the wheels of  Tc and give them to me :signLOL:
Offline candy turbo
« Reply #14 on: October 16, 2009, 09:23:30 pm »
spigot rings uk , they are in bradford  01274 524666   , you need 57.1 dia 5 mm wide  with 45 deg taper :happy2:
