Author Topic: H&R 28/24mm anti roll bars? Should i?  (Read 965 times)
Offline Pikey Motorsports
« on: May 02, 2014, 10:46:32 am »
Whos running these? Should i? Are they really worth the $$$?
I havent done arbs before.. Isit one of the best handling mods?
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline neilc
Re: H&R 28/24mm anti roll bars? Should i?
« Reply #1 on: May 02, 2014, 11:00:17 am »
I have had these on my last 3 of my last 4 cars , a TT QS , an S3 and a TT V6 and they are a great mod sharpening up steering no end and aiding stability as well , they were very effective on the S3. I am also now considering these for my MK5 too..
advertising removed
Offline Tejinder
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,81786.0.html
« Reply #2 on: May 02, 2014, 02:17:17 pm »
One of the best handling mods you can do. I've got H&R ones myself, definitely worth the money
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: May 02, 2014, 02:18:47 pm »
How does the thickness of the bar effect handling/comfort? The thicker they are, the stiffer they are at resiting roll?
Offline Tejinder
« Reply #4 on: May 02, 2014, 02:20:40 pm »
Yeah basically. But upgraded ones are solid bar whereas the OEM rear one is hollow and the OEM front is pretty thin.
The benefit with upgraded ARB's is that they are adjustable too, so you can set them to your needs
Offline th3_f15t
  • -Receive: 183
« Reply #5 on: May 02, 2014, 03:15:24 pm »
Yeah, they're normally 2-way adjustable if I'm correct? Occasionally you can have 3-way but not seen many.
Do you know the thickness of the OEM anti-roll bars?
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #6 on: May 02, 2014, 03:29:46 pm »
The standard front GTi ARB is 23.6mm (hollow), rear is 21.7 (hollow).
I put some info on OEM bars in this thread:
http://www.mk5golfgti.co.uk/forum/index.php?topic=82230.0
Jas
« Last Edit: May 02, 2014, 03:34:11 pm by jason_rmh »
VCDS (Preston, Lancashire)
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #7 on: May 03, 2014, 01:22:12 am »
I've got the H&R 28mm/24mm setup one of the best handling modifications IMO. Such a difference in handling worth the money 100%.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #8 on: May 23, 2014, 08:51:21 pm »
Sorry for tagging on to this thread, but I'm pretty much convinced on a set of ARB's for my ED30, as they made a decent difference on my old 1.8t even with upgraded dampers and springs.
Can anyone advise what the difference would be on the H&R 28/24mm bars vs. the H&R 26/22mm bars?
Thanks!
Edition 30 - no. 1387
