Author Topic: NOT so sweet spot  (Read 2782 times)
NOT so sweet spot
« on: December 08, 2008, 08:52:30 pm »
Just found this on GOLFMKV's
Here's hoping the ED30 doesn't start doing this :sad:
http://www.golfmkv.com/forums/showthread.php?p=1351549&posted=1#post1351549
Offline 182_blue
  • -Receive: 54
Re: NOT so sweet spot
« Reply #1 on: December 08, 2008, 08:56:03 pm »
Doesnt the edition 30 have stronger internals over the normal Gti though?
« Reply #2 on: December 08, 2008, 08:56:45 pm »
Yes, but not the rods AFAIK
Phil Mcavity
« Reply #3 on: December 08, 2008, 09:05:38 pm »
oh dear , Did he get any sorta warranty cover??? with 300+ ponnies?
« Reply #4 on: December 08, 2008, 09:17:56 pm »
I really dont think you guys have anything to worry about. although it is sensational what happened, you would have seen a lot more of this happening by now his is a 08 motor.
Its just one of those unfortunate happenings. Probably a factory defect on one of the associated parts  :chicken:
Phil Mcavity
« Reply #5 on: December 08, 2008, 09:26:48 pm »
Bent con rods are not Factory defective parts TC!!, that bent conrod is concerning, Metal fatique at such a early stage. Warranty claims wont except that at all.  Thats one hefty repair bill for the Customer unfortunatly. Thats a Re-bore and oversize Piston if its scored the cylinder wall aswell. Im guessing it was a Standard GTi with K04 conversion??
« Last Edit: December 08, 2008, 09:32:08 pm by Phil Mcavity »
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #6 on: December 08, 2008, 09:29:50 pm »
I suspect there maybe more to that story than meets the eye........
Red ED35 5dr DSG
BLOG | BUILD
Offline gazbutS3
« Reply #7 on: December 08, 2008, 10:51:04 pm »
It must be because the americans don't get a KO4 version :happy2:
Offline jonnyc
  • Herrooooo!
« Reply #8 on: December 08, 2008, 11:22:03 pm »
He said that he was in 1st then 2nd gear, I suspect there is more to it that that..
Some of the maps out there are running a sh*t load of ignition, this can bend rods without having to run massive power..
If your worried about your rods then its an easy fix, lots of options out there, all of them capable of supporting 500WHP+
