Author Topic: Rear GTI/R32 Brakes  (Read 2374 times)
Offline th3_f15t
  • -Receive: 183
Rear GTI/R32 Brakes
« on: May 03, 2014, 09:49:12 am »
Here is a question for you all. Do the rear brakes on a GTI use the same caliper as the R32, just with a different carrier? In effect, could I just bolt R32 carriers to my stock GTI caliper, swap to bigger discs and pads, and retain the brake line and avoid bleeding?
Offline th3_f15t
  • -Receive: 183
Re: Rear GTI/R32 Brakes
« Reply #1 on: June 12, 2014, 07:14:21 pm »
Looking at piston sizes, in the rear calipers, it appears there's no difference, both use a 41mm piston so theory goes it's just the carriers, discs and pads? Someone's got to know this...
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #2 on: June 12, 2014, 07:23:18 pm »
i could be massively wrong but.... i thing at the least its the carrier that will space it out as the R32 use vented disc the GTI are solid
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: June 12, 2014, 07:39:07 pm »
That's what I mean, so swap to the larger carrier and thicker discs should fit.
« Reply #4 on: June 12, 2014, 11:16:00 pm »
I think the standard rear gti calipers have 38mm pistons. The caddy rear calipers have a 41mm piston
Offline Softishman
« Reply #5 on: June 13, 2014, 09:19:07 am »
Really like to know this!!!
But the 310 disc is vented and thicker then 286 disc, how are you going to fot them in the caliper, it coulden't be so much space left...?! The pads are sitting in the caliper on each side of the disc and is there room for a thicker disc?!
Offline th3_f15t
  • -Receive: 183
« Reply #6 on: June 13, 2014, 09:39:22 am »
Hi
The calipers are different as they have to fit over a 22mm disc in the case of the R32 caliper and only 10mm in the case of the GTI, the piston sizes are also different.
The answer has been given. End of thread. :-(
