Author Topic: HELPPPPPP  (Read 2047 times)
Offline BcPitta
HELPPPPPP
« on: May 03, 2014, 10:06:59 am »
first of all thanks for looking, i tried to fit cruise control to my car yesterday everything went pretty smooth but now my wipers dont work ? i have connected another wiper motor and still nothing. i can squirt water at the windows but no wiper. ive checked over all the fuses a few times and can see no blown fuses. but if someone knows he exact one to check on a 1.9 tdi that would be a great help.
ive read the cars codes and it gave me this :
VCDS Version: Release 11.11.3
Data version: 20120401
Friday,02,May,2014,17:39:50:32264
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ5W111282   Mileage: 224890km/139740miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 1010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 CB    HW: 028 101 190 0
   Component: R4 1,9L EDC G000SG  6176
   Revision: 12345678    Serial number: VWZ7Z0D0696008
   Coding: 0000071
   Shop #: WSC 01392 785 00200
   VCID: 65CBAF4DAC7AE71
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021121
   VCID: 3A712C317544B89
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1K0 820 047 CR
   Component: Climatic PQ35   081 0404
   Shop #: WSC 00000 000 00000
   VCID: 76E9F80101DC1C9
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00H30000    Serial number: 00000001072709
   Coding: 00890F060004181E001400001400000000
   Shop #: WSC 12345 123 12345
   VCID: 3F875D256E669D1
   Component: Fehler Lin-Slave 01
1 Fault Found:
02071 - Local Databus
            004 - No Signal/Communication
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
   Component: 02 AIRBAG VW8   023 0700
   Revision: 06023000    Serial number: 00385D0LK4XL
   Coding: 0012338
   Shop #: WSC 01373 785 00200
   VCID: 31630B1DA8327B1
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 500 0030
   Coding: 0000002
   VCID: EFE74D65FE86AD1
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 951 G
   Component: KOMBIINSTRUMENT VDD 0716
   Coding: 0000401
   Shop #: WSC 11111 111 11111
   VCID: 2D5B176DB40A1F1
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 270010492809AE
   Coding: 3D0F0B40070003
   VCID: 2953E37D80E2031
1 Fault Found:
01305 - Databus for Infotainment
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 180
                    Mileage: 224896 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:04:41
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0716
   Shop #: WSC 00447 210 04708
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
   VCID: 30650E19A338729
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 G
   Component: EPS_ZFLS Kl.2       1301
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 80C802087F008F0F085B018010
   Shop #: WSC 00724 210 104590
   VCID: 7BFFE9353AFE411
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
End   ---------------------------------------------------------------------
any help will be very much appreciated. thanks
Offline Maximum Suction
Re: HELPPPPPP
« Reply #1 on: May 03, 2014, 11:38:33 am »
Might want to check the bonnet switch...
Offline BcPitta
Re:
« Reply #2 on: May 03, 2014, 11:51:50 am »
Bonnet switch works mate as it lets me squirt water which you can't do with the bonnet open. Thanks for your input though matey
Sent from my HTC One X using Tapatalk
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: HELPPPPPP
« Reply #3 on: May 04, 2014, 04:22:35 pm »
The fuse must have blown or the wiring is not connected properly.
The CECM can't see the wiper motor
so that is either the LIN cable or power that has a break in the circuit
Also does your cruise work?
the steering controller is not coded and doesn't support it
Cluster and Key coding
Location Great Yarmouth
Offline BcPitta
Re: HELPPPPPP
« Reply #4 on: May 05, 2014, 09:38:41 am »
hello buddy thanks for the imput, ive removed all the cruise control stuff just to see weather that was affecting it but no luck still. im thinking that the steering control modual may have got damaged some how so im off to see a vw wizz when he reopens tomorrow so fingers crossed. if not ill come back and post the results just hope this nice weather keeps up
Offline BcPitta
Re: HELPPPPPP
« Reply #5 on: May 07, 2014, 08:07:18 am »
SORTED! with a can of compressed air, went round all the stuff again and squirted every plug i could find so must have been abit of grime blocking the connection. 1 happy chappy!
