Author Topic: VCDS issue.  (Read 925 times)
Offline Munzz
VCDS issue.
« on: May 03, 2014, 05:22:55 pm »
Hi All,
A friend recently brought the VAG-COM set up but in an attempt to use it we were unable to do so due to multiple errors.
I was attempting the most basic of commands (one click to unlock all doors) but the following error:
After further investigation, apparently pressing "no" should still work but this error then displayed:
Can anyone advise or point me in the right direction?
Re: VCDS issue.
« Reply #1 on: May 03, 2014, 06:08:47 pm »
try installing the latest 12.12.2 version and see what happens.
And sorry to ask, is it a genuine ross tech cable?
Offline Munzz
Re: VCDS issue.
« Reply #2 on: May 03, 2014, 08:37:32 pm »
Hi,
I think in the end we did upgrade to that version and it still didn't sort it, I'll double check though.
Yes, lead is genuine, should have mentioned that. Rather annoying as it's the only opportunity I've had to have a little play on these and it didn't work, typical!
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: VCDS issue.
« Reply #3 on: May 03, 2014, 09:04:43 pm »
Did you try clicking "Yes"?
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline SI-R32
  • -Receive: 126
Re: VCDS issue.
« Reply #4 on: May 03, 2014, 10:17:03 pm »
Just click yes it will be totally fine for the module your in, I'm totally up to date from Ross tech and get this loads,
Offline Munzz
Re: VCDS issue.
« Reply #5 on: May 04, 2014, 10:48:12 am »
Hi Guys,
Yes, I clicked yes and still got the equipment error.
Re: VCDS issue.
« Reply #6 on: May 04, 2014, 01:32:21 pm »
Is there a fault code for that convenience module?
Offline Munzz
Re: VCDS issue.
« Reply #7 on: May 04, 2014, 02:28:44 pm »
As far as I'm aware, no.
I tried to amend various different modules but still had the same error.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: VCDS issue.
« Reply #8 on: May 04, 2014, 03:48:18 pm »
just use the default or make your own workshop code up
Cluster and Key coding
Location Great Yarmouth
Offline Munzz
Re: VCDS issue.
« Reply #9 on: May 04, 2014, 08:04:03 pm »
Tried that Eddie, left it at all 0's and made my own up.
Will re-install the software again and give it another whirl.
Thanks for the comments so far.
