Author Topic: Allignment / Geometry Setup  (Read 1174 times)
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« on: May 03, 2014, 07:17:08 pm »
Hi,
I have recently had new tyres fitted and in my mind i think i need the alignment done as when i drive on a flat road the steering wheel is just off straight..
My questions are:
Is "alignment" and "geometry setup" the same thing as i've seen both these mentioned on the forum and not sure if one is different to the other.
If these are two separate things then what does each of them change?
And the last one is are there and specific "setups" i should look into so when i go to have this done i can ask if the garage can set it up as so, in order to get the best handling / turning / alignment / steering feel.
As you've probably guessed, I'm not very clued up at all when it comes to suspension / steering / alignment and all that so wanted to get some help / answer that i can easily understand with out being so technical.
If this information helps; the car is not lowered on coil overs / springs / air and has no other handling mods such as walk kits / upgraded bushes / upgraded anti roll bars to my knowledge.
Appreciate any help anyone can offer so i understand.
Thanks,
Carl.
« Last Edit: May 04, 2014, 05:45:50 pm by CarlW »
Offline CarlW
Re: Allignment / Geometry Setup
« Reply #1 on: May 04, 2014, 05:47:17 pm »
Anyone?..  :smiley:
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #2 on: May 04, 2014, 07:09:00 pm »
Alignment and geometry setup are essentially different terms for what could be classed as the same thing.  To you and me that is. If you go to a garage and ask if they do alignment then they might say yes and just do tracking, thinking that's probably what you meant. And it isn't really.
If you're going to pay money to have the geometry set up then you really need a place that does it properly. I'd thoroughly recommend Wheels inMotion if you're near Hemel Hempstead/High Wycombe. They have their own forum where you can ask questions beforehand if you wish. Link.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline CarlW
« Reply #3 on: May 04, 2014, 10:55:20 pm »
Thanks Viking :happy2: unfortunately I'm no where near them as i live in Preston / Darlington so may wait till i go back to Darlington to have the tracking done. At least i know now that there is more to it than just the tracking as you've said above :happy2:
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #4 on: May 04, 2014, 11:01:00 pm »
Carl, I would goto gnj Motorsport down Blackburn way. They are used by a few forum members up our way.
I'm going to them so for wheel alignment. I'm sure they can answer you're questions and are recommended.
Jas
VCDS (Preston, Lancashire)
Offline CarlW
Re:
« Reply #5 on: May 04, 2014, 11:11:59 pm »
Jas
Spot on :happy2: will no doubt have a look up there soon then.. Thanks :smiley:
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #6 on: May 05, 2014, 07:05:58 am »
There's a couple of places in Middlesbrough/Stockton that are recommended on the local VAG forum.
