Author Topic: Edition 30 - sounds like tractor - misfire  (Read 4024 times)
Offline spb
« on: May 04, 2014, 02:50:06 pm »
Returning home from a trip I suddenly felt a lack of power and the engine started to run very bad. It sounds like a diesel on idle and while driving. Also it shakes a lot. The check engine first flashed few times and then stayed on. When I turn it off the check engine is not on immediately, although it idles poorly, but it lights up shortly after driving. I did an auto scan with VCDS. This is how the engine log looks like:
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 T    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G83N68WW
   Coding: 0403000318070160
   Shop #: WSC 78900 924 411174
   VCID: 37775A783FDD
2 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Status: 01100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 41530 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:30:22
             Freeze Frame:
                    RPM: 3399 /min
                    Load: 80.4 %
                    Speed: 136.0 km/h
                    Temperature: 79.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 14.097 V
000772 - Cylinder 4: Misfire Detected
               P0304 - 001 - Upper Limit Exceeded
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 41530 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:30:22
             Freeze Frame:
                    RPM: 3399 /min
                    Load: 80.4 %
                    Speed: 136.0 km/h
                    Temperature: 79.0°C
                    Temperature: 30.0°C
                    Voltage: 14.097 V
Readiness: 0000 0000
What do you advice me to do? Is it a spark plug, coil or I should have changed the cam follower one week earlier :( ?  41k km, sparks, coils, cam follower never replaced :(. One year (10k km) on Revo stage1.
Offline Orc
  • -Receive: 25
Re: Edition 30 - sounds like tractor - misfire
« Reply #1 on: May 04, 2014, 03:12:09 pm »
If I was you I would firstly record and erase the faults then swap a coil and plug over with another cyclinder mate see if it swaps over when you do another scan?
Offline sgour
« Reply #2 on: May 04, 2014, 10:03:08 pm »
When mine had the same symptoms I put in new coilpacks and spark plugs and that sorted it.
Offline spb
« Reply #3 on: May 06, 2014, 05:40:14 pm »
Lacking the technical skills (being a software engineer) and the right tool I didn't remove the engine cover in order to swap the coils but I made a log on engine measuring blocks 015 and 016. After the Malfunction recognition went "enabled" the cylinders 1, 2, 3 misfires remained 0 and cylinder misfires went sky rocket. Looking at the idle rpm and the rise of cylinder 4 misfires there was virtually no ignition on that cylinder (or it was misfiring each time). I'm almost sure I should order 4 R8 coils and 4 spark plugs. Do you advice me different? Like injector gone or coil cables?
« Last Edit: May 06, 2014, 08:25:55 pm by spb »
Offline sgour
« Reply #4 on: May 07, 2014, 07:10:22 pm »
Im no mechanical expert either and the vagcom logs make little sense to me at the best of times. If I were you id just stick new coils and plugs in.
There was a VW recall on the coilpacks so you could check with your VW dealer if your car has had these done, it could save you some money.
Offline byron
« Reply #5 on: May 08, 2014, 11:33:46 am »
Very similar problem to mine, took to a local inpdependant vw garage diagnosed it as a misfire and said someone had broken the coil pack but he'd managed to fix it. Not really knowing any better I left happy thinking my problem had been sorted, a week later te light was back on, a mechanic mate of mine just said to stop by his house and he'd check it, went round and it was misfiring on the same cylinder the garage said they'd fixed, just popped to local motor factors got a new ngk coil pack for 31 quid he fitted and reset the car seemed to sort the problem. Until yday it came back on, it flashed at first then stayed on do I guessed it was a misfire, order myself the little diagnostic computer should come today so I can have a look, then prob just change the rest of the coil packs (which I should have prob done when changing the one??)
I-remap.com
« Reply #6 on: May 24, 2014, 11:11:27 pm »
mine was missing bad, turned out to be 1 and 3 injectors...  all changed runs sweet  :happy2:
Saintsteve
« Reply #7 on: May 25, 2014, 07:19:18 pm »
As above, your injectors and coked up inlet valves will be your issue.
Offline spb
« Reply #8 on: June 23, 2014, 12:42:52 pm »
Replaced spark plugs and coils and it's cured. Made a 500km trip and running perfect.
I was amazed that none of the spark plugs were not wet or smoky. I thought this will be the case if one cylinder has no ignition. I guess the injector was closed by the ecu when detected so many missfires...  :confused:
