Author Topic: engine light on,battery drain,door unlock button not working  (Read 1431 times)
yu6034
HI
my golf engine lights on
battery drain,already changed a new canbus  7N0 907 530 G
and the door unlock button sometimes not working
VCDS Version: Release 12.12.0
Data version: 20130910
Monday,05,May,2014,15:06:37:62939
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 76
Mileage: 112840km/70115miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 A    HW: 1K0 907 115 A
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2233285
   Coding: 040300031C070160
   Shop #: WSC 01287 785 00200
   VCID: 24470A1BE72E243ED0B-8071
2 Faults Found:
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 34
                    Reset counter: 255
                    Mileage: 108537 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 22:59:34
             Freeze Frame:
                    RPM: 1517 /min
                    Load: 41.2 %
                    Speed: 40.0 km/h
                    Temperature: 75.0蚓
                    Temperature: 38.0蚓
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.589 V
009730 - Coolant Pump Control Circuit
               P2602 - 002 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 25.0蚓
                    Temperature: 25.0蚓
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 0.000 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 Q    HW: 02E 927 770 AE
   Component: GSG DSG         070 0925
   Revision: 04007000    Serial number: 00000505300452
   Coding: 0000020
   VCID: 2149030FF83C3116BBD-8074
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   VCID: 408FA68B1376181ED43-8015
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   Shop #: WSC 00000 000 00000
   VCID: 67DD5D1756980F26359-8032
2 Faults Found:
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus - Intermittent
00709 - Sunlight Photosensor 2 (G134)
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2K AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0F3S86
   Coding: 0012875
   Shop #: WSC 01279 785 00200
   VCID: 377DCD5746B85FA6659-8062
   Subsystem 1 - Serial number: 6332MSME0A58635BJ
   Subsystem 2 - Serial number: 6342MSME0A481C63G
   Subsystem 3 - Serial number: 6351HSME07516702
   Subsystem 4 - Serial number: 6361HSME07414618%
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           634 0070
   Coding: 0012122
   VCID: 77FD0D5706389FA6A59-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           007 0050
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 862
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0005103
   Shop #: WSC 00010 707 89438
   VCID: EDD1AF3FF464A576CF5-80B8
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 100611F1000170
   Coding: 350001
   Shop #: WSC 12345 123 12345
   VCID: 3467FA5B97CEB4BE40B-8061
2 Faults Found:
01304 - Radio
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01110100
                    Fault Priority: 2
                    Fault Frequency: 58
                    Reset counter: 3
                    Mileage: 109564 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:09:59
01044 - Control Module Incorrectly Coded
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 1
                    Fault Frequency: 178
                    Reset counter: 255
                    Mileage: 109599 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 03:46:45
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1012
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2410
   Coding: 0000566
2 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 3365F94752C0B386591-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AJ
   Component:    KSG              0401
   Coding: 11C802487F2D8405485AC69010CC
   Shop #: WSC 00999 444 64523
   VCID: 78FF0E6B0B2690DEAC3-802D
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
4 Faults Found:
01135 - Interior Monitoring Sensors
00323 - Vehicle Inclination Sensor (G384)
01134 - Alarm Horn (H12)
00668 - Supply Voltage Terminal 30
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Component: Tuer-SG         024 2470
   Coding: 0000566
   VCID: 387FCE6B4BA650DE6C3-806D
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   VCID: F4E7BA5B974E74BE00B-80A1
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D51EF3FB4E4E5760F5-8078
End   ---------------------------------------------------------------------
Offline ILoveTuna
Re: engine light on,battery drain,door unlock button not working
« Reply #1 on: May 05, 2014, 09:07:57 am »
A few of those probably due to a low/flat battery. I would charge it a few errors clear and scan again.
