Author Topic: Which brakes to go for ?  (Read 4764 times)
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Which brakes to go for ?
« Reply #15 on: April 29, 2015, 11:50:46 am »
For what it's worth, my GTI is standard power, and I've found the stock brakes do fade quite quickly, even though they're fine around town, during normal driving.
I was in Wales over the weekend and there's a stretch of road that goes through the mountains (between Aberystwyth, Newtown, Welshpool etc) that is a PURE driver's road. Straights, sweeping bends, tight bends, vision 2 or 3 apexes ahead, stunning scenery. It's there to be driven.
Unfortunately I managed to cook the brakes halfway through and had to dial it right back for the remainder of the dream road.
So, even with standard power, for me at least, the standard brakes stand out as the GTI's biggest weak point.
Obviously a bigger setup would handle the heat better, but from reading up it sounds like the R32 setup is rather heavy. Which makes me think upgrading to a proper BBK might be the best investment.
In short, whether you're stock or Stage 3, upgrading the brakes will never be a bad idea.
Offline Paradox1
  • -Given: 41
« Reply #16 on: April 29, 2015, 12:00:04 pm »
for your current car spec, I would advise grooved disks, mintex pads, and ATE brake fluid and stainless lines. This will be a good setup and deal with the odd trackday too.
youll be surprised how much of a difference the brake fluid and brake lines will make.
