Author Topic: Diverter valve.help.  (Read 1410 times)
Offline tom38
  • Laser blue,leather,"19s,blue tints
« on: May 05, 2014, 02:56:36 pm »
I have a 55 plate gti and when I accelerate it whistles loads, and when changing gear in boost it sounds like a have a after market dump valve!
I've covered 30,000 miles in this car but lately it seems under powered. ?.
If I get a revision G. Dv, is it possible to fit at home??
Any advise will be much appreciated thanks tom.
Laser blue,leather,19s,blue tints
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Diverter valve.help.
« Reply #1 on: May 05, 2014, 03:12:38 pm »
Hi Tom.
This is discussed very regularly
See here for some detail on fitting: http://www.mk5golfgti.co.uk/forum/index.php/topic,44709.0.html
Plenty of how-to guides on the forum  :happy2:
It's only 3 Allen key bolts so it's not hard, but it's a bit fiddly to get to without a ramp (on a normal GTI).
Offline tom38
« Reply #2 on: May 05, 2014, 03:17:26 pm »
Brill thank you very much, I had it off a year ago now and it didn't seem in to bad condition but it seems a bit gutless now! Thanks for the link tho.
Offline NathED30
Reflex Silver Edition 30 #0063
Offline tom38
« Reply #4 on: May 21, 2014, 07:20:28 pm »
Just replaced Dv with new division g... The one I took off had 3 tears in it and oil everywhere and said on the side it was a revision B....
Smoother idle and better throttle response, I must say that it doesn't seem to have that same acceleration as before it went to pop.
Maybe slightly better torque as the turbo winds up but doesn't seem to pull as aggressive as before?
Dunno maybe I'm just imagining it but at least the problem is gone ! N only took 40 mins yew !
