Author Topic: MDI iphone not supported. help needed  (Read 4450 times)
Offline robson4
« on: May 05, 2014, 09:31:03 pm »
hello
I've retro-fitted the arm rest with the MDI kit as well. i have the RCD-310 which it came with, however when i plug my iPhone 5 in charges but says this iPhone is not supported with this device, is there anyway around this?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: MDI iphone not supported. help needed
« Reply #1 on: May 05, 2014, 09:36:44 pm »
you need the iphone 5 lead
Cluster and Key coding
Location Great Yarmouth
Offline robson4
« Reply #2 on: May 06, 2014, 05:41:12 pm »
I have a USB lead with lighting plugged in will this not work?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #3 on: May 06, 2014, 06:15:00 pm »
You need an iphone 5 Lightning to MDI lead. You can't piggy back through a USB lead I'm sure.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Mullan
« Reply #4 on: May 09, 2014, 10:00:41 am »
So from mdi to phone is just a simple iphone 5 lead?
Offline Mk5Dom
Offline robson4
« Reply #6 on: May 23, 2014, 05:18:05 pm »
okay so i now have the proper lead, the phone connects but there is no sounds?
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #7 on: May 23, 2014, 05:22:18 pm »
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline robson4
« Reply #8 on: May 23, 2014, 05:26:38 pm »
i already have one
Offline DamoP
  • -Receive: 115
« Reply #9 on: May 23, 2014, 05:29:27 pm »
does it charge your iPhone?
Offline robson4
« Reply #10 on: May 23, 2014, 05:31:33 pm »
yes it does, it also shows the song playing
Offline DamoP
  • -Receive: 115
« Reply #11 on: May 23, 2014, 06:22:21 pm »
have you check the plugs on the rear of the head unit? sounds like a speaker/plug issue
Offline robson4
« Reply #12 on: May 27, 2014, 03:47:48 pm »
I've checked the plus at the back and I can't see any problems there, any other suggestions?
Offline DamoP
  • -Receive: 115
« Reply #13 on: June 09, 2014, 04:10:17 pm »
did you ever get this sorted?
Offline robson4
« Reply #14 on: June 10, 2014, 12:33:28 pm »
No I didn't, checked all the wiring, made sure the plugs were in correctly. Still no clue :sad1:
