Author Topic: MDI iphone not supported. help needed  (Read 4428 times)
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: MDI iphone not supported. help needed
« Reply #15 on: June 10, 2014, 04:56:18 pm »
No I didn't, checked all the wiring, made sure the plugs were in correctly. Still no clue :sad1:
have you tried another cable or an iPod lead?
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline robson4
« Reply #16 on: June 10, 2014, 05:27:10 pm »
Yeah tried the iphone 4 and correct lead, still the same result
Offline DamoP
  • -Receive: 115
« Reply #17 on: June 10, 2014, 05:28:01 pm »
that is very strange
Offline Chris01
« Reply #18 on: June 15, 2014, 01:36:11 pm »
Do you know the manufacture date of the donor car for the MDI kit? If you did the retrofit yourself, do you remember if you plugged in a new quadlock cable or just inserted a smaller multipin plug in the existing connector?
Offline Cossie Killer
« Reply #19 on: February 09, 2015, 08:28:28 am »
Morning,
just to reincarnate an old thread, My RCD310 is doing exactly the same... Green collar MDI lead, phone is an Iphone 5, it charges the phone but says the device isnt supported. Cable code is 5N0035554H
Can I assume its the MDI thats the issue? Plug in my Ipod cable and all is fine.
Any ideas?
« Last Edit: February 09, 2015, 08:52:36 am by Cossie Killer »
Offline skard
  • -Receive: 245
« Reply #20 on: February 09, 2015, 10:49:13 am »
What version MDI is it? Pretty sure you just need to update its firmware.
I had an H green lead working on an MDI B and F unit.
See http://www.my-gti.com/3486/volkswagen-media-device-interface-mdi-firmware-upgrade-0530-0546-kw22-2012
Worth pulling out your unit to see what version it is on the sticker
« Reply #21 on: February 09, 2015, 11:12:44 am »
Version B?
Offline skard
  • -Receive: 245
« Reply #22 on: February 09, 2015, 11:14:25 am »
Yes B, I had one and updated the firmware on it and it worked with iphone 6 on an H lead
« Reply #23 on: February 09, 2015, 11:16:54 am »
Ok, so to update, do i have to buy a MDI usb lead?
Offline skard
  • -Receive: 245
« Reply #24 on: February 09, 2015, 11:20:53 am »
Yeh you need a USB lead, probably someoone local with one you can borrow for the two minutes needed
« Reply #25 on: February 13, 2015, 12:03:56 pm »
Thanks for this, it worked!
Only gripe is the sound quality... its awful compared to the iPod, what would this be most likely be due to?
