Author Topic: Edition 30 input shaft play?  (Read 1490 times)
Offline Danpage89
« on: May 06, 2014, 01:26:51 pm »
My edition 30 has developed a horrible knocking grinding noise when clutch pressed and intermitatly the clutch pedle sticks half way. Having looked at it I have found the gearbox input shaft has play in. I've seen some other posts about this but all a few years old just wondering if anyone has come up with a fix or knows any where that can machine the casing due to bearing spinning in case. Any help will be a big help. Thanks.
Offline J12spk
  • VW PERVERT
Re: Edition 30 input shaft play?
« Reply #1 on: May 06, 2014, 01:32:23 pm »
Sorry I can't help with this but I couldn't resist........
INPUT SHAFT PLAY!!!!!!!
Das Auto
Offline wardyed30
« Reply #2 on: May 10, 2014, 09:03:39 pm »
How shore are you on the gearbox input shaft play? Iv looked in to this mine had a slight bit in the box they are not common for doing this it's more the passat box my clutch peddle started doing this I had the box out for other reasons all iv done is replace the slave cylinder
