Author Topic: Snow foam options  (Read 5298 times)
Offline nads1_uk
Snow foam options
« on: May 06, 2014, 09:43:54 pm »
I've been using cg no touch snow foam for some time. Although I rate it is there any others that people would recommend giving a go?
Andy
Offline Marc-5-GTI
Re: Snow foam options
« Reply #1 on: May 06, 2014, 10:51:37 pm »
Autobrite Magifoams are good.. I really like them, what lance do you have?
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« Reply #2 on: May 07, 2014, 12:33:25 am »
+1 with the Autobrite Snowfoam lance
Offline xjay1337
  • -Receive: 377
« Reply #3 on: May 07, 2014, 01:10:05 am »
Bilt Hamber Autofoam is the only stuff that really cleans...use a lot of different foams and it's by far the best for cleaning power.
It is also wax safe up to 7% panel impact ratio.. normally that means about 1 inch of Autofoan in the lance and top it up with water, with your lance set to the highest amount of foam. It does not foam for a long time, it's not a "show foam" as I call them.. it actually cleans.
On a protected car for a weekly wash you can literally foam the car and blow dry it.. totally touchless and it's as clean as if you were to wash it normally.
autobrite magifoam is a second, it cleans much less effectively but it does foam for 20+ mins so if you want a big bubbly snow foam then that's maybe something to look at.
personally going to the hassle of buying the stuff and using it, the point is to remove as much dirt touchlessly to reduce regular wash marring.. so by that reasoning autofoam is the only one i go to and the only use i personally use on my own car.
  • -Receive: 291
« Reply #4 on: May 07, 2014, 07:23:51 am »
+1 for bilt hamber.
Offline Joshy
« Reply #5 on: May 07, 2014, 07:59:55 am »
Sounds like a pretty good snow foam to be honest! Might have to invest in some.
Where do you get it from Jay?
Offline xjay1337
  • -Receive: 377
« Reply #6 on: May 07, 2014, 09:11:20 am »
Google?
Ebay?
Care care / detailing shops?
Cmon, do a little bit of legwork yourself  :happy2:
« Reply #7 on: May 07, 2014, 09:17:06 am »
Clean your car . Co . Uk
DW05 for 5% off. Decent if you're making big order
Offline Hevoshullu
« Reply #8 on: May 07, 2014, 01:50:00 pm »
I've used Magifoam, Valet Pro snow foam and Bilt Hamber auto-foam. Bilt Hamber is by far the best of these three. Recommended. It works great even from a pump sprayer when diluted to 4-8% strength if you don't have a proper foam lance at hand.
Offline alexharvey
« Reply #9 on: May 07, 2014, 09:23:59 pm »
bilt n hamber autofoam is good
also car chem snow foam is amazing and foams more than bilt n hamber and cleans as well
dodo juice ifoam expensive but good too and foams very well
magifoam foams loads cleans ok
Offline DiZzYGT!
« Reply #10 on: May 18, 2014, 09:05:26 pm »
I am currently using dodo juice ifoam and to be honest it didn't perform as well as I hoped. It creates lots of foam and smells nice but still left quite a lot of dirt on the car :/ will be using something else In future.
Offline GLIDN
« Reply #11 on: May 19, 2014, 12:50:11 pm »
Oh wow, finally found a place that ships internationally.
Only a mere £89 to ship a £16.95 products. I guess I will keep trying to find a better shipping rate
Offline jocco
« Reply #12 on: May 19, 2014, 02:30:07 pm »
I thought that Valet Pro is highly rated.
I'm asking as I can get it from neighboring Greece so I dont have to pay silly prices for transport.
Offline Gaz7612
« Reply #13 on: May 21, 2014, 10:06:50 am »
I have found dodo juice snow foam really good at cleaning the car. But it's not the cheapest.
Offline Eccie
  • -Receive: 25
« Reply #14 on: May 21, 2014, 12:09:48 pm »
Currently use Espuma Activo which is very good, also Autosmart's Actimousse is another high performer
