Author Topic: How to change Fuel Pump Cam Follower on 2.0 TFSi  (Read 121897 times)
Offline Pesky jones
Re: How to change Fuel Pump Cam Follower on 2.0 TFSi
« Reply #150 on: September 28, 2016, 05:51:03 pm »
Believe the tsi's have a roller cam follower, but may be wrong.
as far tfsi goes, pretty sure just C
Offline spwd
  • Hello I'm Steve.
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,110133.msg1073872.html#new
« Reply #151 on: December 08, 2016, 06:03:34 pm »
So looks like I'm one of the unlucky ones with the fecking banjo bolt, I've read the whole thread and I'm not sure if I should even try it if there's a big possibility it won't seal correctly, what do you think?
Also any idea how much the no banjo mod costs, and unless I'm missing something it would be a good idea if the mods section had prices :happy2:
http://www.mk5golfgti.co.uk/forum/index.php?page=mods&mod=95
Offline Octoparrot
  • -Receive: 102
« Reply #152 on: December 08, 2016, 06:58:45 pm »
The metal fuel line is the expensive part, I got a secondhand one from the German eBay. The other bits are around £35 from the dealers. The banjo bolt is a pain to do but not impossible. If you end up keeping the banjo bolt I'd seriously recommend using a new one when you're putting it back together as the head can get chewed up quite easily. And make sure you use the correct triple square bit to remove and replace it.
Offline spwd
  • Hello I'm Steve.
« Reply #153 on: December 08, 2016, 07:26:59 pm »
Cheers Octo but what do you class as expensive £100/£300 ?
Also just been Halfords and they've only got 1/2" triple square, absolutely no chance getting that in there  :rolleye:
Offline Octoparrot
  • -Receive: 102
« Reply #154 on: December 08, 2016, 07:59:58 pm »
I don't remember the price but it's more than £100 which seems a lot for a bit of pipe. I got my triple square set from machine mart.
Offline spwd
  • Hello I'm Steve.
« Reply #155 on: December 08, 2016, 08:06:49 pm »
I can't find any 1/4 drive m8s anywhere, might just give up and let R-tech do it .
Offline shoaybmakda
  • -Receive: 54
« Reply #156 on: December 08, 2016, 08:18:36 pm »
The banjo bolt on mine is knackered. I actually managed to get to my follower in the end without removing the banjo bolt but had to prise away very carefully the HPFP after loosening the fuel rails.
Need to get the bolt changed though if I can ever figure out how to get it off in the first place now!
Offline Octoparrot
  • -Receive: 102
« Reply #157 on: December 08, 2016, 10:36:02 pm »
Clarke CHT144 40-Pce Torx® Spline & Bit Holder Set
Back to product list
Product Code 040212750
Manufacturer sku 1800144
£23.99 ex. VAT
£28.79 inc. VAT
Qty
11 reviews
ADD TO BASKET
This Clarke CHT114 specialist driver bit set is suitable for those fixings which, because of their unusual design, aim to discourage tampering and interference. In order to access these fasteners, Clarke...Read more
7 hex bits: sizes from 4 to 12mm inclusive
5 XZN bits: sizes from M05 to M12 inclusive
7 Torx® bits: sizes from T20 to T55 inclusive
3/8" & 1/2" square drive adaptors
This is what I bought
Offline spwd
  • Hello I'm Steve.
« Reply #158 on: December 09, 2016, 12:52:00 am »
Is this the right one and is it 1/4" drive as I can't see where it says, not bad at that price :happy2:
« Last Edit: December 09, 2016, 12:53:34 am by spwd »
Offline Octoparrot
  • -Receive: 102
« Reply #159 on: December 09, 2016, 07:24:17 pm »
Yep that's the one I bought and used. I'd also recommend getting some of those ratcheting spanners if you don't already have some.
Offline spwd
  • Hello I'm Steve.
« Reply #160 on: December 09, 2016, 07:27:42 pm »
Managed to borrow a 3/8 one off a mechanic, not sure if I'll be able to get in with it but worth a try before spending on a set.
Offline J4k3
« Reply #161 on: July 14, 2017, 10:03:26 pm »
Just replaced mine, car is on 64k and no proof of it being changed ever, so wasn't taking any chances. Seems to only have minimal wear so maybe changed at some point in its life.
Couldn't for the life of me disconnect the bottom electrical connector, don't know how people are managing to get to it, as it's in such a difficult place with the clip facing downwards! Didn't seem to effect anything though by not disconnecting it.
Thanks for the guide!
Offline RobC
  • -Receive: 20
« Reply #162 on: July 19, 2017, 12:31:28 pm »
Reading more & more about the Cam Follower has naturally got me feeling nervous! Are there any indicators on age/mileage as to when they start to wear? Ive got a 57 plate Edition 30 but its only on 29k so wanted to know if Im worrying about nothing? Also, how much are the replacement followers?
Cheers.
Offline Pesky jones
« Reply #163 on: July 19, 2017, 12:42:25 pm »
There is no indication or standard ages they wear at. A lot to do with quality of oil. You'll just have to take it and check im afraid. On 29k im sure its fine if the engine is stock. Dont worry yourself unnecessarily, but dont forget about it.
Offline RobC
  • -Receive: 20
« Reply #164 on: July 19, 2017, 04:04:01 pm »
Thanks, will add it to 'things to do one day' list!
