Author Topic: How to change Fuel Pump Cam Follower on 2.0 TFSi  (Read 121772 times)
Offline alexperkins
  • -Receive: 99
Re: How to change Fuel Pump Cam Follower on 2.0 TFSi
« Reply #45 on: June 09, 2011, 07:35:57 am »
I wouldnt thread lock it  :happy2:
« Reply #46 on: June 09, 2011, 07:45:10 am »
Has anyone tried the aftermarket harder wearing cam followers?  I think it was BDM selling them?  Didnt seem worth it when you can get a Genuine one for 24 quid.
I think the harder coated ones were about £80  :confused:
Plus point would be fit & forget for DIY phobes
Offline Boothy
« Reply #47 on: June 09, 2011, 09:36:37 am »
Offline MJR
« Reply #48 on: June 10, 2011, 07:27:31 pm »
Just done this to my "05" reg GTI
Nuts came off fine, changed cam follower even though mine was still in perfect condition, started putting it back together, all seemed well.
Opened and closed driver door a few times, everything seemed ok,
then when I put the ignition on fuel starting pissing everywhere,
seems to be coming from the left pipe nut like its not tight enough but can't get it any tighter, so disassembled it again a few times and then reassemble and still getting the same problem.
30min job my arse, I've been at it since 3pm.
so fuk knows what I'm gonna do now  :fighting:
Should have left it the was it fukin was  :sad1:
Offline gazbutS3
« Reply #49 on: June 10, 2011, 07:37:56 pm »
is the union cross threaded,  undo the union completely and check the threads, once you have dumped the presure :smiley:
Offline MJR
« Reply #50 on: June 10, 2011, 07:39:21 pm »
Done all that, checked everything over and over etc  :sad1:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #51 on: June 10, 2011, 07:50:30 pm »
Have you ensured the ball end of the pipe is correctly seated in the union nut before tightening?
Offline MJR
« Reply #52 on: June 10, 2011, 07:56:54 pm »
yeah all the bits are correctly seated.
Gonna take it apart again tomorrow and try again, as I've seriously had enough today. Sick of of pissing about with cars argh!
might just buy a cheap runabout and none of this crap again  :sad1:
Offline Gti_Mad
« Reply #53 on: June 10, 2011, 07:59:27 pm »
dont be like that bud  :happy2:
im sure it will onli be summin rele stupid n simple
Offline MJR
« Reply #54 on: June 10, 2011, 08:04:16 pm »
seriously the way I feel atm, I've had enough of it.
Supposed to be going away with work next wednesday until August and NEED the car, but atm I can't even put the ignition on  :sad1:
Typical something like this happens days before I go away.
Offline Gti_Mad
« Reply #55 on: June 10, 2011, 08:06:08 pm »
i know how u feel bud iv had feelings like that when things aint goin my way with my car dude
but ur cars gorgeus and u would miss it dude
Offline MJR
« Reply #56 on: June 10, 2011, 08:32:45 pm »
not gonna be gorgeous if I have to spend a sh*tload of money to fix this issue all because of a 20quid cam follower.
Like I say I need this sorted ASAP as I need the car next week for going away with work and if I need to order bits or tow it to a garage, I'm fooked!
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #57 on: June 10, 2011, 09:01:58 pm »
Where are you?
Offline MJR
« Reply #58 on: June 10, 2011, 09:02:53 pm »
Ayrshire, Scotland
bit far from you lot  :sad1:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #59 on: June 10, 2011, 09:05:19 pm »
Ah
Sorry mate if you had been my way i would have come over. Hope you get it sorted soon. :sad1:
