Author Topic: How to change Fuel Pump Cam Follower on 2.0 TFSi  (Read 121764 times)
Offline MJR
Re: How to change Fuel Pump Cam Follower on 2.0 TFSi
« Reply #60 on: June 10, 2011, 09:11:01 pm »
Thanks anyways dude.
As on my other thread:
http://www.mk5golfgti.co.uk/forum/index.php/topic,30749.0.html
Anyone have the part number for the bits mentioned? So I can order some tomorrow from VW just incase I do need them.
Offline Boothy
« Reply #61 on: June 10, 2011, 10:55:30 pm »
seriously the way I feel atm, I've had enough of it.
Supposed to be going away with work next wednesday until August and NEED the car, but atm I can't even put the ignition on  :sad1:
Typical something like this happens days before I go away.
I know EXACTLY how you feel mate. In a similar situation and it really is a pain.  I know what it's like to feel like your just helpless and you really need to sort something.
 Was going to try this myself but feel so not reluctant now. Update the thread when you sort it mate and good luck. Is it defintely pissing out from the fuel line and not something else you've overlooked?
« Reply #62 on: June 11, 2011, 09:55:09 am »
Done this twice myself and not changed / renewed and washers.  Although a little awkward refitting the pipes I never had any trouble with leaking.
Hope you get it sorted soon.
Offline mark01348
« Reply #63 on: June 13, 2011, 02:57:00 pm »
Has anyone changed their follower on an 06. My HPFP has got two metal pipes. The one on right which they all have seems easy to remove but the other looks like a SST needed or something to remove the bolt from the button which goes through the pipe sort of thing. Access looks difficult so I didn't touch it  :confused:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #64 on: June 13, 2011, 04:02:42 pm »
Two steel pipes is a ball ache but can be done.
Stu...
Offline MJR
« Reply #65 on: June 13, 2011, 04:10:28 pm »
Don't go there  :signLOL:
Offline mark01348
« Reply #66 on: June 13, 2011, 06:18:04 pm »
lol really? did you yours have 2 MJR? Read your story, bit unlucky hey. New follower has arrived, might have to go on ebay  :signLOL:
Offline Boothy
« Reply #67 on: June 13, 2011, 06:20:23 pm »
Inspected my cam follower today using this guide and just wanted to say thanks  :happy2:. Without it I wouldn't have had a clue without it.
You can see what mine looked like here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,30046.0.html
« Reply #68 on: June 13, 2011, 08:36:27 pm »
See if this helps. http://www.golfmkv.net/blog/archives/6#
Offline mark01348
« Reply #69 on: June 14, 2011, 09:50:43 am »
Cheers. That looks fun  :signLOL:
Offline marka87uk
« Reply #70 on: October 26, 2011, 07:30:41 pm »
What's the need for the TDC part and is it neccesary?
Also, how would you do it on a DSG?
Steel Grey Edition 30 DSG
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #71 on: October 26, 2011, 08:48:00 pm »
TDC is to take the pressure off the piston should the engine be stopped whilst the cam lobe is at the fattest point thus pushing the piston in.
It's not absolutely necessary and more a precautionary measure. I know a couple of people who have done it without setting TDC.
Offline marka87uk
« Reply #72 on: November 04, 2011, 08:39:08 pm »
Thanks - so how would you go about doing it on a DSG? :smiley:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #73 on: November 04, 2011, 08:49:28 pm »
Not sure mate as never done it. To be honest i think most people skip the TDC.
Offline Digger3
« Reply #74 on: August 13, 2012, 09:42:11 pm »
Checked with the vw-Dealer who's been responsible for all the stamps in the history-book from new, mine hasn't had this replaced it's at 80k now
should I get this done ASAP ?, it's AXX engine code, if so whats reasonable been quoted £66 by an indy...
3DR GTI, Black Magic, Factory Fitted Winter-Pack, Lux-Pack, Colour-Coded Rear Valance, Otherwise Totally Standard, For Now.....
